Home > Puma (Tdci) > Defender Puma blowing brake light fuse!!!! |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
Welcome aboard Bill.
On our side of the world we have lot of issues with brake/tail light wiring in trailer plugs. Often is broken wires inside the plug shorting out. Try unplugging all 3 brake lights and see if it still does it. It will isolate if it is loom or not this way. Cheers, Kyle. |
10th Sep 2015 6:14am |
Unplug the towing socket under the drivers side rear wheel arch and see if it still happens. The back of the socket can get full of water and rot away and the front can get full of mud if you go off road. Ray
10th Sep 2015 9:55am |
Wildbill Member Since: 14 Jul 2015 Location: Aberdeenshire Posts: 11 |
Thank you both very much for you help!!! Where I had fitted the socket in the hole in the crossmember the wire had chaffed on the rectangular hole. So have now taped it up and wrapped it in an old bike inner tube like a grommet and spaced it away from the chassis a little bit. I now have the novel experience of people knowing when I'm going to stop!!!! Thanks guys!!!!
11th Sep 2015 8:13am |
Good pick up, it can be frustrating chasing chaffed wiring.
Nothing worse than studying the mirror when you slow up knowing the car behind may not be paying attention and relying on a red glow. Cheers, Kyle. |
11th Sep 2015 11:42pm |
