Home > Wheels & Tyres > Which tyres wear faster... F or R?
Page 1 of 3 123>
YOLO110
Australia
Interested in feedback on this please... do I put a new spare plus a new tyre on the F or R axle?
I am thinking it would be logical that the F will wear quicker, given it is also steering...
... however!
Cheers, Pete. YOLO... You Only Live Once...
Post #452471 5th Sep 2015 1:09pm
Rickydodah
The tyres with the best grip i.e.new go on the rear axle, ideally in pairs Thumbs Up I started with nothing and still have most of it left!
Post #452472 5th Sep 2015 1:16pm
need4speed
Always put the best pair of tyres on the axle doing the most work. That would be the front. They are driving, steering and braking... All the rears are doing is driving.
Edit: ok the rears are doing a little braking but nothing compared to the front..
Post #452474 5th Sep 2015 1:20pm
gilarion
New tyres on front. Front wheels need the best grip for steering and braking. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #452475 5th Sep 2015 1:24pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
New tyres always on the front. They do more work due to steering and more braking forces.
They also wear quicker than the rears. Make sure they are balanced if putting rear wheels on the front too.
Post #452493 5th Sep 2015 2:43pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
After almost 80.000 km my tires have 7mm profile left. All around... 😳
Post #452523 5th Sep 2015 4:26pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I do a 5 wheel rotation every 3k miles to make sure they all wear the same (I don't do many miles so it only needs doing every 6 to 8 months)
I'd stick the new ones on the front.
Post #452577 5th Sep 2015 7:54pm
shaggydog
Very interesting.
I have just bought a new pair of tyres and was advised to put them on the rear as when your braking hard you want the back to grip better than the front otherwise the back tyres want to be at the front.
Which I was sceptical about but then remember back to when I had use of my dads 206 before I had my 110 or current girlfriend to go and pick up my old girlfriend. He had just had brand new tyres put on the front and while going around a corner the back just completely let go and I did a 270 into a driveway (luckily). When I got home I asked about it and he rang the garage who then said they had put the tyres on the front as requested but usually they put them on the rear.
And before anyone starts the "boy racer" thing - I've not raced anything in my life. In fact I'm possibly the least interested person in racing anything, apart from possibly truck racing.
Just my 2c for what its worth Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #452584 5th Sep 2015 8:11pm
Lambley
Surely it's different though on a 2wd to a 4wd?
As a Defender permanent 4wd it's surely better to put the newer ones on the front as that's where some of the drive, most of the braking and all of the steering is done, I'm no expert though.
Post #452587 5th Sep 2015 8:16pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
“Old-school” philosophy was to put ‘em on the front, nowadays we’re told to put them on the back: if the fronts lose grip you’ll plough straight on, if the rears go you’ll spin or roll over, especially in a truck. Personally, I rotate tyres and when they’ve all worn equally the naff one is used as a spare and I buy four new ones.
Peter
Post #452590 5th Sep 2015 8:18pm
shaggydog
Equally good points Thumbs Up
I too am no expert Laughing
I suppose it makes sense to have the grip at the front, but then that just means you will loose grip at the rear which will cause a spin which is worse? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #452595 5th Sep 2015 8:24pm
YOLO110
Australia
Thanks for the replies!
I don't believe the 'loss of control' or 'skid risk' is an issue as modern tyres retain the same 'grip' on the road throughout their entire life... (assuming they are not left on the wheel for 10 years or so as after this age the rubber can begin to harden/crack). This applies dry or wet but most recommend changing if the tread depth goes below 3mm (not the MOT min legal depth of 1.6mm) as the tyre will then have a reduced ability to 'clear water' which could be an aquaplaning hazard in the wet.
Obviously 'off road', this may be a different story, especially in mud or sand where a deeper tread depth would certainly make a difference I would have thought.
I was more curious about the wear rates, F or R... like others I would have thought F would wear more rapidly as they are simply 'doing more'... YOLO... You Only Live Once...
Post #452630 5th Sep 2015 10:39pm
Rickydodah
As I said in an earlier post, the tyres with the best grip go to the rear. As someone eluded to it's the difference between understeer and oversteer. The last thing you want in any car is natural oversteer, particularly with a vehicle with a high centre of gravity. In an oversteer situation many cars will just spin out, increase the height of the CoG and it's going on its roof, something I don't wish to experience in a Defender with no cage. Anyone old enough on here who remembers when there were X-ply, bias belted and radial ply tyres it was an offence to have the worst performing tyres on the rear for this very reason. The only time it was allowed was with dual wheeled vehicles like lorries, in fact it's still a requirement for all steered axles and all driven axles to have the same tyre construction. So to recap....new tyres on rear...disregard this at your peril. Thumbs Up I started with nothing and still have most of it left!
Post #452633 5th Sep 2015 10:56pm
Alien
Australia
I'd put the new ones on the rear on mine due to them doing more work than the front.
Most of the time it's close to being on the axle weight limits so they are doing more work.
The following is how I see things...
In a 2WD the new rubber is normally put the front for steering advantages.
The best 2 then go to the rear to run out their life.
A 4WD that has 2WD high(think anything with lockable front hubs) they are treated as above.
There is a disadvantage to this though and that is when 4wd is selected.
The different tyre diameters, front to rear can lead to extra tread wear on harder surfaces.
On an 4WD that is normally AWD, like our Land Rovers you should keep an eye on wear and rotate as necessary.
If 2 new tyres are put on at either end the different rolling diameter leads to excessive centre diff wear.
On a Land Rover this is evidenced by the transfer box oil getting contaminated by brass from the gear shims.
This picture was from the old D2 upon disassembly.
I say go 4 new tyres, keep them rotated.
The best 2 tyres go to spares,1 for daily driving and the 2nd for when going remote touring. Cheers,
Kyle.
Post #452635 5th Sep 2015 11:12pm
need4speed
I agree with rotating after a period of time.
As for the comment about putting the best tyres on the rear that's just wrong, wrong, wrong.. Doesn't matter if it's 2WD or 4WD. Think about it. The only way the rears will want to overtake the front is if your entering a corner hard on the brakes like a rally driver - hardly the kind of driving a defender sees.
Also, in these days of ABS the rears would never want to do that under normal breaking/conditions anyway.
Whether it's 2WD or 4WD - best tyres should go where most of the work is happening. The front.
Post #452712 6th Sep 2015 9:32am
Page 1 of 3 123>
