Home > Puma (Tdci) > Help: loss of power and black smoke from exhaust
Def Junkie
Mine is a 2009 2.4 TDCI with an Alive Tuning re-map. Felt a drop in power recently and had the filters etc checked and replaced where necessary. Still didn't get back the extra perkiness that one gets after an Alive remap. Have also noticed that she burns quite a bit more fuel than usual and also black smoke from the exhaust after the engine is heated. The temp gauge is normal. Grateful for your customary help and advice. Cheers, Tim
Post #451097 1st Sep 2015 2:13pm
First point of contact, should be Alive, really.
Though I'm guessing a split or blown off intercooler hose.
Hoping you sort it fast.
Post #451099 1st Sep 2015 2:21pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Check the pipes from intercooler, and around the turbo.
Is it making any strange whooshing noises? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #451101 1st Sep 2015 2:25pm
ian series 1
Greeni beat me to it! Wink 80" 80" 86" 88" 90"
Post #451102 1st Sep 2015 2:27pm
Def Junkie
Not quite sure it is a whooshing sound but intermittently have heard a loud noise from the engine. Not a rattle or anything. I suppose one could call it a whooshing sound. Will have the hoses checked once again although I had that cleared at the time of replacing the filters. Could a split hose result in extra fuel consumption and black smoke?
Post #451103 1st Sep 2015 2:38pm
landy andy
A faulty intercooler hose could. Check them near the steering shaft.
Post #451112 1st Sep 2015 3:27pm
ericvv
I had a split intercooler hose once. A whooshing sound on the highway, especially if trying to go to speeds higher than 90kmh. But no black smoke at all, and no other engine sounds either. Dealer replaced by new, but recently have switched to stainless intercooler pipes which are available for the Puma 2.4 engine.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #451118 1st Sep 2015 3:44pm
Davie L
Scotland 2008 Defender 90 Puma 2.4 HT Orkney Grey
Where do we get the stainless pipes from??
Post #451188 1st Sep 2015 7:49pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Black smoke is caused by the car running rich. So check for loss of turbo boost pressure.
Things like a egr stuck open, water gate stuck, failed boost pipe/intercooler, clogged air filter.
And failing that over fueling from a bad injector or similar.
But 1st get hold of Alive and see if they have had it happen before
Post #451190 1st Sep 2015 7:55pm
Def Junkie
Many thanks for all your help. Will have them checked out and report back. Very much appreciated. Bow down Bow down
Post #451254 2nd Sep 2015 12:21am
Def Junkie
Just realized that I had mentioned Alive. My re-map is actually from BAS. Embarassed Have just written to Pete. Cheers.
Post #451256 2nd Sep 2015 12:34am
