Home > Puma (Tdci) > Heated Mirror Wiring |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 |
Most common way is to wire them separately from a relay (usually in the seat box ner the battery. The activation pin on the relay is fed from a splice from the windscreen wiring. That way you're only using the windscreen wiring to provide a relatively low current to the relay, which provides an independent fused supply to the mirrors.
Generally wiring it to the window switch makes sense as you want the mirror heaters on when you need the window heated. Otherwise it'd be another switch taking up space on your dash! Make sure you protect the cable when it passed through and sheet metal, and when it's near the doors, so it doesnt chafe and short out. |
31st Aug 2015 10:03am |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1833 |
Tim, you'll probably find this of interest
http://defender90xs.blogspot.co.uk/2014/10...ation.html 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
31st Aug 2015 10:22am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
31st Aug 2015 10:40am |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 429 |
Have a separate switch (and relay) for the heated mirrors
I find that in the rain/mist/drizzle the heat will keep the mirrors clearer from water and you would not want the heated screen on |
31st Aug 2015 10:45am |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
Installing Mirror Heating to a Land Rover Defender by Espen S. Johnsen :
http://la7dja.org/defender/mirror-heating/ Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
1st Sep 2015 7:57pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Not once have I bothered with a separate switch I always used the heated screen switch with absolutely no issues The draw is well within the switch and wiring tolerances
As always your motor your choice |
2nd Sep 2015 5:47am |
Oh its 1.55 amp per side
5th Sep 2015 7:38am |
Lops Member Since: 17 Jun 2019 Location: Worcestershire Posts: 7 |
so do you wire directly into the switch or off the relay? sorry electrical noob |
7th Nov 2019 3:34pm |
ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731 |
Mine come straight off the screen wiring, as I always want them all on at once - haven't had a problem since I fitted them (8 years). Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
8th Nov 2019 9:48pm |
