Home > Technical > Removing lt230 transfer box
Mike.s
Hi,
Going to be removing my transfer box and gearbox tomorrow. Everything is disconnected and ready - i`ve got the floors and seat box removed and i `ve got an engine hoist.
I want to remove them seperately as i think it`ll be easier to handle and seperate reconnect,etc.
The space behind the transfer box back to the chassis cross member looked a bit tight to me to enable the input shaft off the gearbox to disengage, so i`ve removed the handbrake drum. A thought just occured to me - most of the guides on the internet show removing the input gear cover and the input gear itself to replace with a crossdrilled gear - do i need to remove the gear to take the transfer box off?
I`m not replacing the input gear at the moment as i`ll do at a later date if its worn, but thought i`d just check before i start trying to remove the transfer box and run into problems!
Cheers, Mike
Post #450415 29th Aug 2015 7:41pm
davew
No, on a standard setup you don't need to remove the cover.
For future reference, you can remove the lt230 from underneath the vehicle without removing the floor, seat box etc... Unless this is part of a bigger job. It's always worth removing the brake drum and backing plate though if only to keep the weight down when handling the transfer box. http://www.yorkshireoffroadclub.net/
Post #450455 29th Aug 2015 10:38pm
StephenO
I removed gear/transfer box and handbrake all together in one go. Once removed I then split them, once all the bolts are undone the transfer box just slips off no need to remove anything else.
In hindsight the only thing I would do is loosen the bolts between the gear & transfer box some of these were bloody tight. We removed it through passenger door. Thumbs Up 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey
1968 Series 2a Bronze Green
1995 Defender 90 Coniston Green
2005 Discovery 3 Zambezi Silver
Post #450456 29th Aug 2015 10:50pm
Mike.s
thanks guys - off out now to have a look at getting them out. fingers crossed this rain holds off!
Post #450478 30th Aug 2015 6:32am
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Mike from memory I am 99% sure the input gear is a decent cross drill one...as I think I swapped it over when we installed the disco transfer box Thumbs Up
N.
Post #450481 30th Aug 2015 6:37am
Mike.s
cool - i hoped that was going to be the case! Smile
Post #450483 30th Aug 2015 6:48am
Anderzander
Oooo good to know you can remove it with the floors in place. I wasn't sure all of the bolts were accessible with them in.
Post #450564 30th Aug 2015 11:01am
Mike.s
Found my clunk culprit! Not sure how much longer this would have lasted!
Nidge - Input shaft gear was a new cross drilled gear with no wear Smile
Unfortunately i pulled my back a bit wiggling the transfer box off the gearbox - combination of tight space and an awkward position to be pulling with Sad So all done for today.
Will see how i am tomorrow but will probably have to be next weekend really i guess. Definitely putting it back together outside the car and back in as one unit. I think next i`d remove it as one aswell!
Floor and seat box stripped out - this didn`t take that long really. I had to cut off just two bolts which had rusted up.
And not much left on these splines!
Post #450569 30th Aug 2015 11:19am
Fossil
United Kingdom 1997 Defender 110 300 Tdi CSW Coniston Green
I read a tip to cut the heads off 3 180mm M10 bolts, cut slots in the end, & wind them into the M10 bolt holes. Then you can guide the transfer box straight off or on to the gearbox. Worked like a charm for me. You were lucky the mainshaft had held. Nigel
Post #452263 4th Sep 2015 6:24pm
Mike.s
yep - i think mine was fitted with studs on one side - unfortunately, the box was a bit stuck on them coming off, which with me tugging from the side aggravated that old back injury of mine - feeling alot better now though Smile Got a few bits to sort tomorrow, then have a mate coming round on monday night to give a hand taking the old off and fitting the new Smile
yes, glad the mainshaft didn`t go before now!
Post #452294 4th Sep 2015 7:31pm
