Home > Maintenance & Modifications > Decal removal
AndyTunn
New Zealand 2008 Defender 90 Puma 2.4 SW Stornoway Grey
Decal removal
Hi, I'm trying to remove the DEFENDER decal from the back of my car. I'm using the "heat and peel" method but it's taking for ever. After 30 mins or so I'm now the owner of a "DEFENDl" !! I'll be here all night at this rate. Confused
Does anyone have any tips for removing decals?
Post #450270 29th Aug 2015 7:37am
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
My usual method is to boil a kettle and pour it over the sticker then use meths or white spirit on residual glue. It's your call tho, I can't guarantee anything.
Post #450273 29th Aug 2015 7:58am
Rallymental
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
Razor blade or Stanley blade?
Post #450276 29th Aug 2015 8:09am
Hair drier works well, plus a good chemical to remove the glue. A blade is useful to start off, then heat and peel.
Post #450278 29th Aug 2015 8:18am
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
On the bodywork of a defender?!
Heat gun, patience, then Autoglym tar and glue remover.
As an aside, On plastic moulded decals, like the defender wording on the bonnet, fishing line is a good method of reomving the plastic, before attacking the adhesive pads left behind..
Post #450295 29th Aug 2015 9:23am
McGeordie
United Kingdom 2014 Defender 110 Puma 2.2 USW Montalcino Red
As others have said, heat gun or hair dryer, get it nice and warm and work from a corner and peel back at a shallow angle..I did mine and it didn't all come away in one piece, so when it breaks, apply more heat to the next section and so on, you should get it in about 10-15mins.
Please don't try anything else, even if you don't slip...the risk of damaging your paint work is too great.
Post #450298 29th Aug 2015 9:44am
YOLO110
Australia
Re: Decal removal
This will be so frustrating for you, but I literally peeled mine off last week with absolutely zero prep or effort! But it had only had 8 weeks to 'set' from new!
Hairdryer works well mate... just take is slowly. Anything that is left can be removed with acetone and a clean rag. Thumbs Up YOLO... You Only Live Once...
Post #450311 29th Aug 2015 10:31am
K9F
No prep for me neither. I just raised the end with a Stanley knife blade and very carefully and slowly peeled it off. Looked a bit bare afterwards so a few months later I replaced with the raised lettering.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #450332 29th Aug 2015 12:36pm
Superchippy
United Kingdom 2015 Defender 110 Puma 2.2 XS DCPU Aintree Green
3M make an adhesive remover however always be careful with solvents on paint work, do a test on some hidden paintwork.
Post #450380 29th Aug 2015 5:23pm
Superchippy
Post #450381 29th Aug 2015 5:24pm
LR90XS2011
ditto with the hair drier, white spirit for the glue remnants DEFENDER 90 TDCI XS,
Post #450401 29th Aug 2015 6:57pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
A plastic putty knife won't cut into the paint work, use it instead of any metal tools.
The best thing to use is heat, and patience. Once the sticker is off, adhesive remover or Acetone and lots of patience.
Post #450404 29th Aug 2015 7:12pm
AndyTunn
Re: Decal removal
Haha! I think that's the basic problem - mine has had 7 years of high-UV New Zealand sun to bake it on!
The largest piece that I've got off so far is about the size of a fingernail! It seems especially prone to breaking at the boundary of the grey letters and clear background.
I'm using a plastic trim removal tool to help - I didn't want to risk anything metal.
Ah well - back to the task this morning. I'm about half way there now. Thanks for all the tips folks!
Post #450420 29th Aug 2015 7:50pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
I took the stripes off the side of my boat this year and found that warm, I could take a fair amount off in one go but overheat it and the plastic went brittle and snapped.
Maybe experiment a bit with the technique.
My boat's over 10 years old, so it was well baked on.
Best of luck! 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #450433 29th Aug 2015 9:08pm
AndyTunn
Finished! Thanks everyone for the tips and encouragement! See http://www.defender2.net/forum/post450465.html#450465 for the end result.
Post #450466 30th Aug 2015 4:18am
