Home > Td5 > windscreen heater/vent
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Guys I've had the clocks out today to see why my car wouldn't blow on to the windscreen on the drivers side.
I found a large hose connected to the part that blows on the screen and the bottom on a wonky angle.
I've fitted it straight over what appears to be a breather duct for the hot air and connected it to the plastic scoop that blows it onto the windscreen.
Success I have some air blowing onto the screen. Very Happy
But it still leaks at the bottom, should it be connected to something or inside the hole? It doesn't want to go in as it seems too big, it is also huge where it connects to the scoop part and had to be really tightened up to get any kind of fit
Do I have the correct parts in my landy or are they all like that?
Post #448035 21st Aug 2015 2:02pm
jabber
United States 1986 Defender 110 Other SW Oslo Blue
Sounds about right. There's a "ribbed" hose that fits inside the rubber attachment to the heater box. LR could have made them a few mm longer so they fit easier; but they just barely fit. Certainly not air-tight by any means.
I've been meaning to tear that all apart and improve it; but it's fallen on the list of things I have to do to the deefer.
Post #449258 25th Aug 2015 11:33pm
gazman
Thanks. Will see if I can improve on this and will let you know
Post #449262 25th Aug 2015 11:53pm
