Home > Maintenance & Modifications > LED Bulbs
Simali
United Kingdom 2004 Defender 110 Td5 CSW Zambezi Silver
LED Bulbs
Hi
Does anyone make / has anyone tried replacement LED bulbs fir sides indicator etc?
Post #446573 16th Aug 2015 7:42pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Sorry if I misunderstood the Q but did you mean like this? - http://www.mudstuff.co.uk/front-rear-73mm-led-lamp-kit.html
Post #446582 16th Aug 2015 8:07pm
Simali
Post #446590 16th Aug 2015 8:28pm
Dora
Yes, I did a few years ago and they are rubbish! They have a very low viewing angle so they are only any good if you are directly behind or infront of them. They also don't last long!
Post #446605 16th Aug 2015 9:00pm
leeds
They are also illegal to use as a replacement for a standard filament bulb as the type approval would be void.
Brendan
Post #446614 16th Aug 2015 9:15pm
Simali
Thank gents will steer clear then
Im new to Defenders and just feel a bit vunerable with those tiny tail lights.
Post #446668 17th Aug 2015 6:14am
Buccaneer
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
There are two options, both of which have been mentioned.
One is replacement bulbs - these are illegal as Brendan rightly points out.
The other is proper/complete LED units (bulbs and lens etc) as per the Mudstuff link. These are EU Approved.
So yes you can beef up your brake lights, side lights and indicators (will need to change the relay for the latter to get right blink rate) The Rules:-
1 Buccaneer comes back alive.
2 Chicks dig scars.
GB260
Post #446678 17th Aug 2015 7:06am
