![]() | Home > Maintenance & Modifications > Can I mount speakers into Cubby Box? |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
A friend of mine has done this in his ex military 90. stuck the speakers in each side. can't remember what size they are (if they're 5" round or 6x9's)
Obviously the sound isn't going to be fantastic, but better than whistling and singing to yourself! |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 ![]() ![]() ![]() |
Basically no matter the size/brand of the speakers, you won´t get any good sound unless the box is somehow sealed, ehich is not the case of of any Defender front dash. Puma 110" SW
mlightfoot Member Since: 10 Jan 2009 Location: Cheshire Posts: 86 ![]() ![]() ![]() |
Thanks - thinking of mounting in cubby and then sealing them off inside the cubby, making the storage space smaller but hopefully better sound.
I fitted mine in the lower part of front doors using a thin wood spacer. I´m not planning to wad that deep and these are std coaxial pioneer 16 cm speakers. Also got a pair of good adjustable twitters (Lanzar) for the upper dash. It is far for being a pro system, but it does the job much better than the factory rubbish speakers. Can post some pics if you are interested. Puma 110" SW
MK - yes pls
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Puma 110" SW ............................................................. Earth first. Other planets later |
Looks great thanks MK!
For anyone interested, don't mount in cubby box, they sound awful ![]() |
Aäron Member Since: 26 Oct 2010 Location: Sedella Posts: 27 ![]() ![]() |
how did you mound the little top speakers??
