Home > Series Land Rovers > RIVET GUN for SOLID RIVETS |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Keith Wadsworth, from Wadsworth panels sells them.
Google his name, not much to buy, and do a great job. Although you do have to go careful with them! I also have a manual one for hard to reach areas, looks a bit like a g clamp. A forum member on the LRSOC makes them, Bob Jones. They are not cheap, I paid £100 for one of his, but invaluable if restoring one. Hope this is of help 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
28th Jul 2015 6:09pm |
Here is the sort of Finnish you can expect to get.
All the cappings replaced on mine. Click image to enlarge Click image to enlarge 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
28th Jul 2015 6:14pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Ian,
Many, many thanks for the information. Excellent job you've done there. I wonder whether anyone has taken the pop rivets out behind the Defender door and replaced them with solid ones? At least they wouldn't rust! Thanks again Ian You're a Top Bloke |
28th Jul 2015 6:27pm |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 286 |
Try this supplier, not cheep - http://www.aetools.co.uk/product-rivet-squ...nd-901.php NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
28th Jul 2015 6:40pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17563 |
The tool you require for economically cold forming aluminium alloy rivets is called a rivet snap and is widely available. Type "rivet snap" into Google and you will find many. They are not expensive.
A rivet gun is only needed for hot forming steel rivets, such as when making rivetted boilers and other similar structures. Rivet guns are hard to find and very expensive. |
28th Jul 2015 9:42pm |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 248 |
i visited keith wadsworth a couple of years ago and bought the tool. It fits in my air-chisel and although i've never used it it looks easy. 1953 80"
1987 mini city e 2011 90" |
14th Aug 2015 4:38pm |
Not that easy when fresh paint is concerned.....
Great bit of kit though. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
14th Aug 2015 5:12pm |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 462 |
Hi Guys,
Thanks for bringing this up. I have this job to do in a few places on my S1 so will check out these tools.Cheers, John. 2.2 90 XS 88" Series One Old Norton Minerva |
14th Aug 2015 9:45pm |
