- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
nitram17
Hi gil to change the subject did you ever solve the security problem (screwdriver )with the murrey snap off!you can pm me if you dont want to say publically!Its just i have not got round to it yet!
2nd Sep 2015 4:32pm |
gilarion
No a little bit like you I have not got round to it yet! It’s on my jobs to do list. I have worked out that I need someone with an engineering lathe to fashion me a centre to similar dimensions to the plastic retainer that is fitted now, then I will probably fix it in situ with two small snap off bolts. Sounds like a plan. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
2nd Sep 2015 4:48pm |
nitram17
I iam going to change my name to "iwilldoittomorrow"I thought the same as you but i was just gong to glue it! if i come across a bit of ally tubing the right size i might just use that instead..if ist slightly too big i will chuck it in the freezer and hope it will shrink to fit!
2nd Sep 2015 5:01pm |
