Home > My Defender > My new (to me) Defender 90 Puma
Page 22 of 34 <123 ... 212223 ... 323334>
Venomator
For the price I would have expected a retaining strap, or similar, over the top to keep it in place in case of rough ride turbulence, or a roll over... Shocked
Tidy is one thing, occupant safety is something else... Mr. Green
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #481343 11th Dec 2015 5:45pm
SailingTom
/\ pretty much useless for securing with out a strap over the top.
Id mount it over a leather belt so you can secure it in the storage, would go with your leather trim aswell Thumbs Up
Post #481355 11th Dec 2015 6:24pm
tonyhedge
2014 Defender 90 Puma 2.2 SW Montalcino Red
Nah, if you are upside down and it is mounted in the recommended position on the seat box, just catch it between your thighs before it reaches your chin Shocked . Simples! That's not a dent, it's a rivet. That's not a dent, it's a rivet. That's not ... oh! That is a dent!
2014 90 XS SW
1997 Discovery 300TdiS (retired to stud)
1966 Series IIA 88" (now my son's)
2001 Astra - I need something to go and buy the parts when the others are off the road!
Post #481411 11th Dec 2015 10:48pm
RRUK
Firstly, if I am upside down then I will have many more things to worry about than if the Ardcase is coming out of its holder!
So, today, despite the constant rain I decided to get on with the interior refit.
First things first I fixed the headlining up with the long fir trees, drilling 4 mm pilot holes into the roof rib, then opening them up to 7mm. A rubber mallet helped knock the clips up firmly, and because I had sprayed them matt black, they blend it perfectly and it looks REALLY smart. Thumbs Up
Next I had to remove the seat belt mounts, as you can't fit and adjust the seat riser rails with them in place, an easy task, they are held in by a 10mm nut at the rear and a 13mm at the front, each into a rivnut in the seat box.
Before the seat was put in I fitted the Ardcase carrier to the front of the passenger seat box, it's not a small unit so it fits well here, and with no seat in place there's easy access to the back of the box by the battery.
Next was fitting the passenger seat, which went in fine, a little adjustment on the rails to lift the rear a bit then tighten up.
Once the seat was in, I could see that luckily, there's enough space underneath to access the battery with jump leads, without a removable base and without having to remove the seat in total.
The seats both went in fine, then the seat belt mounts (a tight fit compared to the OE seats), and then finally the cubby box. once they were all in, tightened down and I was happy with the adjustment range it was time to put the dog guard back in.
The finished result, with the black alcantara headlining, the beautiful LRI leather seats, the tall leather cubby and the Startech leather wheel all go so well together. The interior ir amazing.
 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #481817 13th Dec 2015 6:00pm
JAY BOY
Wales
Looking very plush.
Mud interior lights next Question
Post #481819 13th Dec 2015 6:12pm
RRUK
No but I have ordered LED CANBUS festoon bulbs to replace the originals for a bit of extra light inside. 2016 D4 HSE
Post #481827 13th Dec 2015 6:57pm
fathaggis
it looks stunning mate Bow down enjoy Thumbs Up
Post #481831 13th Dec 2015 7:14pm
JOW240725
Does look great! Thanks for the update on the arcade storage. Thumbs Up
Post #481836 13th Dec 2015 7:28pm
RRUK
Do you mean Ardcase storage?
I guess the iPhone made it Arcade! 2016 D4 HSE
Post #481837 13th Dec 2015 7:29pm
L110CDL
looking really good, those seats look like once your in, you dont want to get out off them quickly, super comfy Thumbs Up
Post #481882 13th Dec 2015 9:23pm
g-mack
perfect interior now Thumbs Up very subtle looks amazing. how are you finding the seats in comparison to standard ones? My 109 thread
my youtube channel
Post #481972 14th Dec 2015 11:19am
RRUK
I've only had a short drive so far, but initial impressions are very good. They are much firmer, the seat base is longer and more supportive and despite these being the low base versions, they still have a figure hugging feel t the base, the seat uppers are just lovely, they cosset you, it's like being hugged!
Seat heaters worked fine and so I'm a happy camper.
I'm out shooting on Friday and Saturday so this will be the first decent shake-down for it, as Friday is just over an hours drive away. 2016 D4 HSE
Post #481988 14th Dec 2015 11:54am
Stacey007
Hello
What seats are they? they look great, did you have them trimmed like this or it that off the shelf?
Thanks
Post #481992 14th Dec 2015 12:03pm
RRUK
They are off the shelf by LRI, a forum sponsor who will give you 10% forum discount too.
http://www.lrisolutions.co.uk/index.php/la...-1993.html 2016 D4 HSE
Post #481995 14th Dec 2015 12:13pm
RRUK
The LED festoon bulbs I ordered just arrived, a 10 second replacement, seems much brighter even in daylight. The proof will be tonight.
 2016 D4 HSE
Post #482085 14th Dec 2015 3:56pm
