Home > Technical > amber engine warning light |
Ickle,
As you are aware a US gallon is actually considerably less than an Imperial gallon...to that end I use the Scangauge litres option instead. Not really interested in the cost side of things with regard to fuel but Scangauge being a US produced item the gallon setting would most certainly be innacurate from a UK point of view. I too reset a MAF fault and deem the purchase a useful tool! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
16th Sep 2010 6:06am |
