![]() | Home > For Sale & Wanted > (SOLD) Patriot 0.9 roof rack and ladder |
That's the same rack (albeit without the luggage rails) I have fitted. It's ideal for someone that doesn't want the weight or carrying capacity of a full rack. Not sure what you'd do with the ladder inless you've a single cab as that is what they were for? You could mount it at the rear I suppose? Excellent rack. I made new clamp rubbers out of butyl pondliner. Good luck with the sale.
![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 ![]() ![]() ![]() |
Does the ladder attach to the rack or the roof at the top? If it attaches to the roof then would you consider selling it separately?
Harry |
Paul Rover Member Since: 15 Aug 2011 Location: Kent Posts: 61 ![]() ![]() |
It attaches to the rack at the top. I would consider selling separately.
Pictures here it attaches to the rack as stated:
http://www.defender2.net/forum/topic24201....iot+ladder If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Boyd Member Since: 11 May 2014 Location: Le Saint Posts: 172 ![]() ![]() ![]() |
I would take the ladder on its own at the right money
![]() 2004 Santorini Black TD5 110 XS SW left hooker for sale! 2004 Alpine White TD5 110 left hooker (work in progress) |
how much for rack on is own
Bother, I'm after one that attaches to the body because my rack is not a Patriot. Good luck with the sale
