Home > Technical > Engine "pinking"
mse
Engine "pinking"
Heard a "weird" noise yesterday after doing no more than about 5 miles (to get fuel)
It didnt do it for long, cant remember what the engine temp was but it was at higher revs say 2500 - 3000 in possibly 3/4.
Im not sure it is pinking - what does that sound like though? Mike
Post #38090 14th Aug 2010 9:22am
K9F
Not very good at describing noises but i'll have a go.... Rolling Eyes
I once had a Ford that was notorious for it's pinking....the noise had me convinced that my cam chain tensioner was knackered.....it was a 'high frequency metallic' knocking sound....normally, I believe caused by pre-ignition where the fuel ignites before it's supposed to opposing the engine mechanics. (Fuel ignition occurs before the piston reaches TDC trying to force it against it's stroke). The situation is the same, as is the noise when you turn off the ignition and the engine runs on!
Sure someone else can describe it better or correct me if I am off the mark. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #38093 14th Aug 2010 9:38am
RobKeay
Don't know how old your 90 is. But I have had a funny engine problem with mine. I took it in and landrover have reprogrammed it. It is running very well now. I believe that the factory have installed the wrong ecu software.
Post #38121 14th Aug 2010 8:25pm
mse
Mines had the engine software updated - thanks anyway
I couldnt make it do it today - so probably nothing.
But still interested in the general pinking noise. Mike
Post #38134 14th Aug 2010 10:43pm
