Home > Puma (Tdci) > Defender 110 tdci power problems |
Mogboy Member Since: 21 May 2013 Location: Brisbane Posts: 31 |
You could try cleaning the contacts to the accelerator pedal. Remove the connector, spray with contact cleaner, replace & check.
The potentiometer assembly inside the box on the pedal could also be at fault, which would require replacement of the acc pedal unit. I'd probably also clean the clutch sensor contacts on the clutch master cylinder while at it. Or....it could be something else. |
1st Jul 2015 10:00pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17448 |
Any DTCs logged?
1st Jul 2015 10:26pm |
