![]() | Home > Technical > Rear interior trim removal... |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1646 ![]() ![]() |
Hi Guys and Gals,
Help please! I have an MY14 Puma 110 and want to remove the rear trim panels around the windows to fit Panoramic glass. When I removed the small plastic covers over what I thought were going to be screws or fir tree's just inside the rear door panel and along the top of the panel, what I can see under the caps look like rivet heads! Has JLR started to fasten these panels with rivets... which will mean I will have to drill them out? Or are these just press stud fastenings that will pop off with a bit of leverage? I don't want to crack anything! Any ideas please! Cheers, Pete ![]() |
57 views and no ideas?
LRmud Member Since: 22 Oct 2014 Location: IV12 Highland Posts: 198 ![]() ![]() ![]() |
Sorry, but I can't help other than suggest that since its a 2014 model, you take it along to your friendly local dealer for his advice.
Mine's a bit older and the rear interior trim is 10mm plywood which comes off with a screwdriver bit in a battery drill. Simples! ![]() Best of luck. ![]() 1989 Defender 90 Toyota Aygo & Honda FR-V |
Cheers mate! Yes, screws were what I was expecting to find given what is noted on the 'net'!
Oh well... I guess a trip to my local dealer will indeed be the next step! ![]() |
If I'm understanding what your saying you mean the trims for the two small windows next to the rear door. If so under the small caps there should be rivets but these don't need touching. Just grab the trim panel close to the rear door and pull it towards the front of the car and it will come off as the clips that hold the trim on just push on. Ray
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
The rivets you are referring to hold the spring clips to the trim, whatever you do don’t drill them out! The side trims are held by spring clips along the top edge so you should be able to manoeuvre the trim out once you jiggle it a bit to release the clips you should have fir tree fasteners on the bottom of the trim. The trim is held in place by a combination of fir tree fasteners and clips. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
http://www.youtube.com/user/conwy1 |
This might also help with the removal and fitting
http://www.vehicleglazingspecialists.com/p...guide.html For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Perfect!!!
Many many thanks for the replies... ![]() Pete ![]() |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 357 ![]() ![]() ![]() |
Having removed the rear trim panel to fit a ladder can anyone advise where I can buy replacement spring clips from?
Ebay
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...SwKIpV-twF Ray My build thread http://www.defender2.net/forum/topic17615.html |
Thank you
Recently ordered some from Paddockspares. Seems cheaper than ebay.
http://www.paddockspares.com/btr6682-edge-clip.html Same time ordered some of these plastic trim rivets from them which you may need if you start taking the rear trim off and back on... http://www.paddockspares.com/rivet-2.html Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1117 ![]() ![]() ![]() |
Supacat ,on the second diagram , do you a part number for the 3 screws/fixing ? And can these be replaced with the fir tree clips EZM100340LOY .
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1866 ![]() ![]() |
Yep, I know this one dates back a few years, but it's what google pointed me to.....
I've had my car for something like 19 years, and never had the rear quarter trim. It didn't come with a set, but I've now got some. I can see that I need the clips (referenced above) to attach the trims to the door frame. BTR6682. I found one of them attached to the car after all the years. I can get more of them. No problems. But..... how does this trim panel fit / connect to the side window trim? I haven't any photos to hand - which would certainly help - maybe tomorrow. There seems to be a sprung 'leaf' bracket attached to the rear quarter trim, but as far as I can see, nothing for this to link / connect to on the side trims. I guess I must be missing something? Or.... they are meant to just 'tension' or 'brace' themselves against the side trims, and be fixed into the other clips? I know this is quite hard to describe, but if this has made sense to anyone else, please let me know what you can. While I'm on the same sort of subject. My side trims just have the 'big' hook/clips, which I assumed were just meant to hook onto the internal guttering. Now I see on the parts diagram that there are smaller versions of the clips above - MWC6203 - are these supposed to clip onto the guttering, and have the trims hook into them?? Thanks as always. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
