Home > Maintenance & Modifications > 2ND ROW SEAT SPACE EXTENSION SETS - EXMOOR/HOFELE |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Hi everyone,
Ive done a search , but cannot find any other post so has anyone installed these brackets to reposition the second row of seats in a 110 or 90? Thanks. http://www.exmoortrim.co.uk/store/hofele/l...etail.html |
18th Jun 2015 3:14pm |
I don't think they lift the back up. I just think as there are four brackets they just go under the front legs which if they do will increase the rake angle and increase the height of the front.
I don't know for sure though |
18th Jun 2015 4:14pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17390 |
It certainly looks as though that's all they do - tilt the whiole seat structure backwards slightly so that your legs hang down straighter and hence create the illusion of more legroom.
I suspect that they can only be used in an SW or USW and will not fit in a double-cab since there is insufficient clearance between the seatback and the back of the cab. I wonder if they actually make the "sitting experience" more comfortable! |
18th Jun 2015 4:28pm |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1833 |
I got all excited when I saw this as the little 'uns are kicking the bejesus out of the back of my seat, so moving the 2nd row back would be a bit of a God send. But alas it seems just to change the angle of the dangle 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
18th Jun 2015 6:20pm |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 683 |
You could always go to twin singles in the rear and move them back on custom mounts? That's my only way out I think if I want to get four adults in comfortably for long distances. Strangely the biggest issue isn't actually leg room for me, its how high the head of the occupant is, you have to stop down to see out the side windows. My brothers about to take the seats out the back of his 130dc, just not viable for distance use if you're tall. More room for the fridge and the sub though!!
18th Jun 2015 6:25pm |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 597 |
Don't really see how these help with leg room but could be great for another problem, the backs are just too upright. I wonder what angle they give. I think the red line in their diagram is a little ambitious as front is only raise by 2-3cm.
Really wish we could have different recline options on the middle and rearmost seats but if they can't even make the standard front seats go back like in every other car for the last....??? |
19th Jun 2015 10:21am |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 |
Just ordered a set, So will post a before and after pic if anybodies interested ?
Cheers Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
20th Jun 2015 8:51pm |
Fullfat Member Since: 30 Apr 2014 Location: Lincolnshire. Posts: 271 |
I would love to see the before and after pictures and your thoughts on if they improve things, my son is 6"6 and is always moaning about the lack of leg room, so I'm keen to find a solution also.
Cheers |
22nd Jun 2015 7:12pm |
Click image to enlarge Click image to enlarge Sorry for the images being on their sides... But I hope this helps.. Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
25th Jun 2015 3:55pm |
so what are they like to sit on with these brackets fitted ?
25th Jun 2015 4:57pm |
Much better... Where as with the original position you feel too upright and there is no support under your legs. With the Seat brackets fitted the backs are at a much better angle and the seat cushion is in a much better place and it supports much more of your legs..
25th Jun 2015 6:21pm |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
ive just fitted some of these, well worth the money. with child seats fitted its gives them more leg room also
30th Jun 2015 5:09pm |
Does the bracket kit do both the double and single rear seat? I can see in your picture the single seat seems more upright ?
30th Jun 2015 6:46pm |
Yes, This was taken so you could see the difference between the before and after..
1st Jul 2015 7:15am |
