Home > In Car Electronics > Disapointing Audio Upgrade :-(
Page 2 of 2 <12
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Thanks Steve, will do some reading.
More expense Very Happy
Post #431826 18th Jun 2015 7:17am
Thumbs Up
Post #431873 18th Jun 2015 10:40am
barbel jim
Barney, Not sure you'd need anew head unit..... without being rude have you played around with the H/unit set up ? Is it running the active sub correctly with the Low pass filter ? The standard alpine 133 has plenty of adjustment ? My only criticism is the Bluetooth keeps crashing with my 6! Redrobs suggestion of the Alpine 178BT would be a good one as it is cream with regards BT integration.
Post #432015 18th Jun 2015 9:47pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
A good way to spend more money is buy a set of front and rear door cards from la salle, they have speaker housings moulded into them, I ran two sets of 5" Rockford fosgate component speakers, with a 10" sub in a one off box, alpine head unit and two small but mighty powerful Rockford amps, with proper cabling and connectors and cable routing it sound amazing , I really can't fault it for any type of tunes I have put through it,
It was a big bill for parts but I installed it all myself over a few weeks,
Also used dynamat every where I could put it
Post #432048 18th Jun 2015 11:45pm
Barney12
redzob wrote:
I think the biggest improvement was actually upgrading the HU to the Alpine 178BT, mainly because it supports the Alpine TuneIt app on my phone. And it was an easy swap.
Just to update this thread. I had a frivilous momment and picked up a 178BT online for not too much money.
Straight swap fitment in 10 minutes and its definitely a big improvement on the original HU.
Still not great but for now I am going to live with it as I dont want to start hacking door cards etc.
TTFN
Post #434565 29th Jun 2015 2:04pm
scotiach
Switzerland 2015 Defender 110 Puma 2.2 SW Scotia Grey
1) With that HU you can use the time alignment or DTC as Alpine call it to center the 'stage' where you want it: center of dash or over steering wheel, etc. This makes a huge difference. Don't bother time aligning the sub. RTFM
2) Then use the EQ to tune the sound to your ears, music and vehicle. You only have 9 bands but that corresponds to octaves in the range. RTFM
3) You can also set crossovers with that HU, taking out sub-100hz frequencies from your 4 inchers - this will clean up their reproduction as they will not produce these frequencies very well (frequency response), freeing them to concentrate on the frequencies they can handle. I don't remember if you said thy were coaxial or not though (tweeter built in). use a steep crossover slope. RTFM
4) Low pass the sub at max 100hz on steep slope, don't worry if you low pass the sub at say 63 and the 4 inchers are high passed at 100 or 120. It's less than an octave and both sets will reproduce a little bit of this range anyway (high pass/low pass just attenuates, it doesn't cut completely.)
5) Listen to your full range of favourite music while tweaking points 2 -4. At first, all will sound crap, then some will sound ok, some crap, then everything will sound ok, then most will sound good and so on. It can take many hours of driving and listening and tweaking.
6) Upgrade options after doing all this are: a) amp your 4 inchers with enough rms watts to push them a little. you can set gains so that they are only getting the right amount. Modern digital 4 channel amps can be fitted without too much bother in the fuse box area under the seat. b) Hoik the rears out, and replace them with some 6.5 inchers, amped as above. This will fill the thin area a lttle between the sub low pass and the main speakers. Even using the same high pass as your 4" inchers (say 100-125 ish. As the 6.5ers have a better frequency response at these frequencies (ie they play louder with the same input watts). You need to cut the speaker surrounds but it's easy and they're cheap to replace.
When doing 2-5 don't be shy about switching off via the HU the rears, fronts, sub as you tune. I rode around for a day (2 hours commute) with just the sub playing, trying different crossovers and EQ settings. I mainly listen to country music and 80s, not hardcore trance. Same for just my front 4 inchers. In fact for a while (2 weeks) I only had these fitted at all. It was an audio upgrade on an iPhone in my top pocket, but not by much.
Also, downloading an RTA app to measure the frequency levels allows you to apply some objectivity to your adjustments. You can get 'pink noise' tracks on the web to tune your EQ using the RTA.
It sounds like a faff but with a really simple set-up and some tuning elbow grease, you can get great results without spending a load of money.
Post #434996 1st Jul 2015 8:37am
Barney12
Some great advise there, thank you.
Looks like I'll be needing to buy more tea bags! Smile
Barney
Post #435025 1st Jul 2015 10:56am
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Re: Disapointing Audio Upgrade :-(
Barney12 wrote:
Hi All
In my continuing attempt to sink the equivelnt of the Greek national debt into my 2014 XS 90 Stationwagon I've upgraded the standard audio as follows:
Alpine SWE-1200 Active Sub - This is bolted to the cubby.
2 sets of Alpine SXE-1-25S - 4" 2-way drive units - Replacing the standard front and rears.
Alas though I've been disapointed by the results. Its certainly loud enough but the sound seems incredibly flat with a very poor mid range and trebble.
I'm now considering changing the head unit? or perhaps my choice of speakers was poor?
Or is it just my expectations from an aluminium can body are just too high?
Hurrumph!
Barney
I did nearly the same upgrade as this but I also added the behind dash Alpine amp.
It made a huge difference and I'm really pleased with the results. The amp provides the 45RMS the speakers need to really get going.
Post #436527 8th Jul 2015 2:45pm
Barney12
Hi, interesting info. I see you went for a more powerful 4" speaker than me.
Did they fit without too much issue? They look quite deep?
Post #436546 8th Jul 2015 4:13pm
K9F
Yannis...Your picture rang bells with me. I fitted what must have been the predecessor, the KTP 445 slimline amplifier from Kenwood four years ago. Compact and very effective. I had to reconfigure the connector as it was being fitted to a non-Kenwood H/U.
K9F wrote:
"The KTP-445 fits behind the head unit in the dash of most vehicles. It's small and compact at only 7" x 2-1/2" x 1-3/8".
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #436548 8th Jul 2015 4:29pm
Yannis
This amp being Alpine just plugged straight in, there is enough wire with it to mount it about anywhere within a 20m radius....
The speakers I went for were the SPG-10C2. In the Puma there is loads of room behind the speakers, I could have gone even deeper if needed. They didn't come with speaker grills but I pulled the original ones off the speakers and they fitted just fine.
Post #436556 8th Jul 2015 5:26pm
rodspink
This is my home made 6x9 setup.
With clever use of brackets I didnt drill a single hole in bodywork. Also bought a cheap pu skirt from primark and used this to cover it by gluing and staples .looks ace.
Rod
Post #438564 17th Jul 2015 1:36pm
rodspink
Rod
Post #438567 17th Jul 2015 1:42pm
Page 2 of 2 <12
