![]() | Home > Technical > Which screws for chequer plate? |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
My black 3mm plating came with countersunk m6 nuts/bolts/washers, I guess none came with the kit?? If not the the easy way is to use rivets
foxing Member Since: 20 Sep 2008 Location: south wales Posts: 80 ![]() ![]() |
these may be what you are looking for http://www.a2stainless.co.uk/Land-Rover-De...AZI51.aspx atb paul |
Froogle-Yorkshireman Member Since: 10 Jul 2010 Location: Yorkshire Posts: 350 ![]() ![]() |
I swapped out the OEM supplied fixings for Stainless Steel from Flatdog. Not on their website but give them a call. Proud owner 110 Utility XS
Ex RR Sport HST V8 Ex Td5 90 |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6652 ![]() ![]() ![]() |
If using stainless use a jointing compound on them, such as Duralac or the German stuff that comes with the bolt kits Brendan supplies
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
I sourced black ali fixings for mine no corrosion issues
![]() Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
Landydefender1 Member Since: 13 May 2015 Location: East Yorkshire Posts: 63 ![]() ![]() ![]() |
Out of stock |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 287 ![]() ![]() ![]() |
If you're after Stainless bolts try Westfield Fasteners, excellent service see attached link - http://www.westfieldfasteners.co.uk/ScrewBolt_M.html NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
jonesie Member Since: 25 Sep 2011 Location: Petworth Posts: 231 ![]() ![]() ![]() |
Hi Landy,
I have got some new Black Stainless Pozi ( the correct screws/ length ) in stock if you are still after some. Jonesie Series I 86" Petrol orig side valve (daily hack) VW Tiguan ( bit bland but very comfy ) Porsche 997.2 790 Bonnie |
