Home > Australia & New Zealand > indicator stalk , 3rd lucas replacement not disengaging.
soulfuelshane
Australia 2001 Defender 110 Td5 USW Coniston Green
hi all, are there any after market recommendations re alternate brand /supplier for indicator /high beam low beam stalk for 2001 defender .this is my third instillation in 3 years. initially no high beam , then no return after cornering . Driving me nuts.
thanks.
Post #426854 28th May 2015 10:47am
munch90
relay the headlights (search headlight upgrade loom ) that will remove load on the switch for headlights , but wont help the self cancel on indicators
check to make sure steering wheel lug is locating in the collar in the switch ,seen sometimes switch slides back the steering lug comes out of collar
Post #426856 28th May 2015 10:57am
soulfuelshane
thanks munch, will look on the weekend. Its mainly the indicators as the low beam on the defender is awesome .
Post #426858 28th May 2015 11:05am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
That stalk has been driving me mad as well. They've replaced it a couple of times and, I even put the original steering wheel back to see what it does. Well... After a couple of months it's starting to act up again from time to time... Big Cry
Still have a year of warranty left, but actually can't be bothered to mention it again at the dealer.
Post #426871 28th May 2015 1:22pm
OCD
Mine has just been back for the 5th time since Jan for this. The Steering Angle Sensor has been changed this time which, so far, seems to have fixed it.
Post #426873 28th May 2015 1:25pm
