Home > In Car Electronics > Rear Load liner and Rear XS HT Speakers |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20583 |
I'd cut as little as you can, remove the speaker panel and put it on top if which is unlikely it's too tight a fit shave a small amount off the panel.
The eyelets I'd poke through. Depends how permanent you want it of course too. If it's going to stay put a long time them fit it as I've suggested if you want it in and out often then you'd be better off cutting. Be careful though and measure twice cut once etc etc. |
27th May 2015 6:34pm |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 |
I've the same choice to make now and I'm going to go with cutting the liner for two reasons ...
The speaker panel ledge is big and i think would look a bit ridiculous on the top of the liner - it looks like it's designed to fit under the CSW carpet. Also the panel has a recess at the bottom where it looks like the CSW carpet would fit into - thus my plan is to cut the load liner to follow the inner contour of that, which should give a seamless / factory look. |
27th May 2015 7:14pm |
watts Member Since: 01 Feb 2015 Location: Somerset Posts: 71 |
Thank you both, very kind.
Tried both ways and ended up going with cutting the liner, as Ander says the groove around the base of the speaker housing worked well to fit cut liner around it. I also completely removed eyelets and bolts drilled out the holes in the liner and used them to hold the the thing in place. Liner is actually quite easy to cut with a sharp pair of scissors. I can post pictures if required, it's quite simple just got to make sure as Steve says measure twice cut once. |
27th May 2015 10:06pm |
I guess if you do cut it'll mean you can get it out easy too if you need to, I always find with any sort of matting you often get a dirt and debris layer between the matting and the body underneath that needs cleaning out once in a while.
How do these stay in place are they semi rigid or some kind of fastener? I may think about similar one day as I'm sure it'd have a sound deadening effect. |
27th May 2015 10:31pm |
