Home > Maintenance & Modifications > Cargo net
Page 2 of 2 <12
jackl
England 2012 Defender 110 Puma 2.2 XS CSW Zambezi Silver
So cargo net all fitted, bar a couple of very small tweaks. I have to say it took longer to install then I expected but everything is bolted back to reinforcing bars in the car so should do the job. The nice thing is it takes seconds to remove and can be used to secure things to the roof rack if out and about and spot a bargain.
Since receiving the net, now had additional net made with sheet attached to fix the oztent to the roof. Again this is well made and looks really good. Very Happy
Post #430630 13th Jun 2015 11:15am
AndyTunn
New Zealand 2008 Defender 90 Puma 2.4 SW Stornoway Grey
Wow that looks neat! What are the bottoms of the webbing "uprights" attached to?
Post #431834 18th Jun 2015 7:36am
looks very industrial (in a good way Thumbs Up ) - how did you fix the cargo rail to the roof brace?
Got any photos of your roof net?
Post #431839 18th Jun 2015 7:57am
jackl
morning all,
The cargo rail was fixed at the top into the roof rail with M8 rivnuts behind the roof lining then bolted through holding the lining in place. The small side pieces of rail bolted through the channel running the length of the car with M6 bolts and reinforcing plates behind. As for the bottom I used the small black anchor plates shown below bolted through the shelf.
The roof net pictures below. Thanks for the comments I am well happy with the finish.
Post #431858 18th Jun 2015 8:51am
Now that is outstanding Thumbs Up
Just watch some of those metal clamps don't "chatter" on the side rails and rub off the paint.
Post #431863 18th Jun 2015 9:03am
jackl
The really nice thing on the clamps is the strap runs underneath so only the webbing touches the rack. Although good point I may length one side and tighten the other make sure.
Thanks
Post #431866 18th Jun 2015 9:15am
Page 2 of 2 <12
