SOLD Honda EU10i Generator
Am selling our Honda Generator EU10i
This is a library image as have not had a chance to photograph it.
Details are
Primary usage Leisure Use
Type Portable
Max output (W) 1000
Voltage stability (%) + or - 1
Output voltage (V) 230
Rated output (W) 900
Frequency rating (Hz) 50
DC voltage (volts) 12
Power Stability Inverter Technology®
DC current (amps) 8
Engine type GXH50
Type single cylinder 4-stroke OHV air cooled
Starter system recoil
Length (mm) 450
Width (mm) 240
Height (mm) 380
Dry weight (kg) 13
Noise Level (1/4 load) (dB(a)) 52
Run Time, up to (hrs) 8
Fuel tank capacity (litres) 2.3
Fuel type Unleaded petrol
This has been used at shows to provide power for the caravan.
It has been regularly serviced . Latest service was today.
Looking for £400.
It can be collected from the Land Rover Spring Adventure Show or collected from Halifax. We might be able to arrange carriage via courier, (will have to check couriers prohibited items) however it will have to be emptied off all oil and petrol.
Reason for selling it? We have just bought a 2.2kW generator to power caravan, extra fridges and other electrical appliances used at shows.
Brendan
18th May 2015 7:45pm
Blacktt600
"Extra fridges"
Hopefully for the EXTRA beer?
18th May 2015 7:51pm
leeds
Well I could argue that post is OT
Lets say one of the fridges is on freezer mode at the moment being filled with Barbara's home cooked food.
Now which beer do you want?
Coconut? Peach? Cherry? Mango? The Mango is apparently very nice.
You will require handsaw, large hammer, spirit level and some large gauge screws this weekend
