Home > Puma (Tdci) > decat and centre box removal does it affect the turbo
st86
England 2011 Defender 90 Puma 2.4 CSW Tamar Blue
As per title does fitting a decat and centre box removal pipe make any difference to the turbo will it lag or not
Post #422406 10th May 2015 4:21pm
Anderzander
If anything it will spoil faster with the decrease in back pressure.
Post #422416 10th May 2015 5:18pm
Anderzander
Oops - auto correct got me and I can't edit on the mobile site --- spool faster - not spoil
Post #422417 10th May 2015 5:18pm
K9F
Plenty of information already available, here's a starter......
http://www.defender2.net/forum/topic7482.html?highlight=spool If you go through life with your head in the sand....all people will see is an ar5e!!
Post #422425 10th May 2015 5:27pm
Lorryman100
There is not much of a difference from having the CAT removed to having one fitted, source a renowned tuner.
So much so I got a new CAT from Dan at Duckworth parts and it is going onto my Puma next week. The main reason is the acrid stink from the exhaust fumes that the CAT filters out. JMTW Thumbs Up
Post #422427 10th May 2015 5:32pm
Likeomg
i prefer not having one, it does make the turbo spool quicker and sounds meatier.
Post #422431 10th May 2015 5:49pm
K9F
^+1 but rearbox instead of centrebox. Differing opinions but glad I did it.
bell-auto-services wrote:
You may want to consider a Decat front exhaust, this will help the turbo spin up faster and free up the whole system. Regards Pete
Noticed the difference on mine straight away. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #422436 10th May 2015 6:15pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
^^^^^^^what he said^^^^^^^ Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #422437 10th May 2015 6:20pm
pannawonica
Australia
I noticed two things once the cat and centre pipe were removed. First the engine had more power and spooled up much faster, secondly a huge reduction in heat in the cabin. On long trips +1000 mile no power drop due too heat. It seems too me that the exhaust heat can now flow away from the vehicle/engine which is all good! Very Happy Thumbs Up
Post #422532 11th May 2015 2:37am
Naks
I removed the cat on mine, noticed turbo spooling up much quicker.
Will also remove the centre silencer box, noticed lot of heat coming through on a recent trip in high ambient temps (34C) --
Post #422538 11th May 2015 6:22am
Egghead
Heat killed my manifold and turbo Sad both were cracked! ££££ Evil or Very Mad Since removing cat and centre silencer the engine has been nice and smooth, it sounds rather nice, and my cab has been cooler too. Engine now remapped and EGR disabled. From a cold start the diesel smell is a bit stronger and the soot deposits around the exhaust exit are blacker these days but at least that Censored isn't going back into my engine anymore.
Post #422581 11th May 2015 10:23am
Lorryman100
I have tons of engine live data taken from my Puma with the decat fitted with an Alive stage 2 remap. I am planning to take more live data with the cat refitted. Once the mot is done in September I will base the two sets of live data on whether to keep the cat or refit the decat. Thumbs Up
Post #422733 11th May 2015 8:29pm
st86
Hey guys thanks for all the responses definitely thinking ill do the decat now before i take it to bas for a remap do they still go through the emissions test for the mot without the cat and egr disabled?
Post #422739 11th May 2015 8:48pm
munch90
No emissions check for diesel as such , only smoke test for mot at the moment
only visible check for cat for mot , if you get a switched on tester without a cat is a fail
Post #422740 11th May 2015 8:52pm
