![]() | Home > Maintenance & Modifications > LOIRE BLUE 110 5 door station wagon Pictures |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Hi All
Does anyone own and have any pictures of the above type fitted with Landy Glass, My friend wants some pictures for a project. Regards Pete |
Thank you ill pass it on to my friend to see if it helps his plans. Nice car for sure.
Would be good tuned also if it ever takes your fancy. Regards Pete |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 287 ![]() ![]() ![]() |
It will be at some stage - just working out exactly how far I want to take it!!
Beautiful Colour that.
Still cant work out why they dropped blue off the colour pallet ![]() Self confessed mileage hunter ![]() |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
If it was available for the 15my I'd have had it
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Darcy Fairfax Member Since: 05 Oct 2014 Location: London Posts: 721 ![]() ![]() ![]() |
Properly nice colour that, goodness knows why they took it out of the MY15 palette :bang: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
I was told they'd have to have 60+ requests for Loire blue, to re-open the paint lines at the factory. I was about 2 weeks too late! |
Nearly silly question, but can you get it any colour you want if you go via the SVO branch?
Just wandering if it would be cheaper to buy a white one get it stripped and repainted then reassembled by a specialist or to get it done at the factory. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
From factory, standard colours only.
If you did want full respray I would pick a colour close to what you wanted or complimentary to the colour you wanted to go for; because unless you are going to dismantle everything there will always be evidence of the original colour. |
I suppose the closest to blue would be black then given the current choices? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
That would be my choice.
My dealer only had scotia grey or aintree metallic on the forecourt the rest were solids. Probably would have had montalinco red if I could have seen one in the flesh first to make up my mind. However loire blue would have been my choice if I were able to have it...... 2002 90 Td5 Station Wagon
JJ440 Member Since: 08 Nov 2013 Location: Geneva Posts: 51 ![]() ![]() ![]() |
Don't know what I own now anymore
![]() What's the difference between Oslo and Loire blue? |
