Home > Maintenance & Modifications > Mantec roof bars making a racket 😮
Boris
Evening all
Fitted 3 no mantec roof bars to my puma and you get to around 45mph and the noise is unbearable , it stays (although gets less) till about 60 mph Big Cry
I reckon it's the front bar that's the problem , cos if I put my hand out of the window and grab hold of it you can subdue it a little and feel it vibrating like mad Rolling Eyes
Soooo has anybody else had the problem and how did they sort it ?
I fitted a mantec snorkel at the same time and wondered if maybe the wind/ airflow going around the snorkel is not helping Banging Head
Help please !
Post #418439 23rd Apr 2015 6:10pm
leeds
Try moving the position of the front bar and see if that improves the noise.
Brendan
Post #418456 23rd Apr 2015 7:46pm
Boris
Thanks Brendan , I'll give it a whirl , it's right at the front at the moment , so will try moving it 8" back and give it a try
Post #418458 23rd Apr 2015 7:58pm
leeds
If it is right at the front then I could imagine air hitting the windscreen divert upwards hitting your Manbo bar causing the noise.
It might take a couple of attempts to get it right.
Brendan
Post #418461 23rd Apr 2015 8:16pm
I've got two on mine, might be the Snorkel causing a different airflow party as I don't have one.
But no noise from mine!
The front one is located just above the frontal first section of flat roof.
So above that section but just behind the seam of the sloping section heading down to the windscreen.
If that makes sense?
Post #418510 23rd Apr 2015 10:21pm
Boris
Cheers Steve
I've moved the front one back to about half way along front door , and I'm pleased to say everything is tickety boo Thumbs Up
thank goodness for that Mr. Green
Post #418700 24th Apr 2015 4:26pm
Thumbs Up
Post #418706 24th Apr 2015 4:41pm
