Home > Puma (Tdci) > D44
D44
Would this fit my 57 puma 90 size wise ok? http://www.devon4x4.com/products_a/p1688c1...black.html I know which side (right) but i notice they don't have the Puma there only Tdi td 5 ect.
Thanks Thumbs Up
Post #36212 13th Jul 2010 9:29pm
K9F
Yes it will fit! I just had a look at the Safari Snorkel fitting instructions that show the OEM trim removed revealing screw positions! Why not consider a RAI instead?
http://www.safarisnorkel.com/snorkel/ss1130hf/ss1130hf_guide.htm
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #36213 13th Jul 2010 9:40pm
I would consider a RAI but i'm a young driver and a RAI would be a mod? Also cost is a factor Embarassed Reason i want replacement is because the original one come off (plastic clips c'mon LR!) broke off. the way i see it is that behind this vent there are 5 screws that hold the intake ducting to the body so as a temporary measure i drilled 2 holes in the COVER and removed two of these screws and used them to hold the vent cover on. I can't not have it there in case debris flys in. I would imagine that the D44 Stainless screws would be a little longer to allow for this so these 5 screws hold the vent to the panel and the intake duct to the panel at the same time. Hope this makes sense
Thumbs Up
Post #36215 13th Jul 2010 10:07pm
