Home > Puma (Tdci) > MAP sensor cleaned |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
Just for interest, after cleaning out the grime and soot from the MAP sensor which is very easily removed from the steel pipe at the inlet manifold. The puma took about three driving cycles to become much smoother and no more jerking when cold. Even the tail pipe has much less soot now and no smoke on start-up.
Worthwhile doing if you have similar symptoms as me. It may be the cleaner diesel helping now that we again have access to the 50 ppm but by the amount of gunk on the sensor, I am sure the cleaning helped a lot. Last edited by CapeLandy on 13th Jul 2010 7:30pm. Edited 1 time in total |
13th Jul 2010 8:21am |
And now BLANK the EGR!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
13th Jul 2010 9:35am |
Only in February next year
By the way, do you just blank the pipe joining to the intake manifold or on the outlet from the exhaust manifold? |
13th Jul 2010 10:32am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
CapeLandy, do you have some pics of how it looked when dirty? |
13th Jul 2010 10:51am |
picture somewhere in here
http://www.defender2.net/forum/topic3577.html |
13th Jul 2010 11:06am |
Cape, Page 3 of this thread I posted pictures on how to do it: http://www.defender2.net/forum/topic3115-30.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
13th Jul 2010 3:47pm |
Brilliant - thanks - missed that section before. K9F I notice on one closeup that you are also missing a bolt on the exhaust manifold just aft of the heat shield - mine is also gone I assume from the bumpy dirt roads |
13th Jul 2010 6:00pm |
Robofarmer Member Since: 17 Mar 2010 Location: cheshire Posts: 88 |
How are you going on with your EGR kit dgardel ?. have you had time to fit it yet 2008 110 County utility ex 1988 defender 90 ,td ex 1970 series III |
13th Jul 2010 8:16pm |
Thanks for the 'heads up' matey about the missing bolt I never even noticed! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
13th Jul 2010 8:33pm |
