Home > In Car Electronics > Is there more than one Double DIN size head unit? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20547 |
In what locations doesn't it fit? Or are we slaking just too big or too small?
8th Apr 2015 8:28am |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
Busman was a member here - I don't believe he makes the double din dash anymore
You need to remove the bracket that holds the old single din stereo at the back Also you may need to slice the bottom of the clock off And the vent pipes may need bending back |
8th Apr 2015 11:33am |
No 1 Member Since: 04 Apr 2015 Location: Oxford Posts: 9 |
I've since had a call from TMC. I didn't realise that you have to fit the stereo, then fit the panel; I thought the panel went in, then the head unit went in to the panel.
I'll have another look this evening armed with this info. It should make it easier as there will be more room to work around getting all the other cables in the back of the head unit (DAB aerial, SAT aerial, reversing camera, sub-woofer, etc). Would have been handy if there had been instructions supplied.... |
8th Apr 2015 12:27pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
That's not entirely true.
You don't fit the stereo in the dash and then put the trim over the top, you fit the stereo to the trim from behind, (rather than through the front as you were trying to do) and then the trim with stereo attached is fitted to the dash. It is a tricky job and will take you some time to do and get right. |
8th Apr 2015 12:40pm |
Thanks Go Beyond - will set plenty of time aside. Luckily, I've not sold my car so the Defender's not required and is sitting on the drive with its dash ripped out at the moment!
8th Apr 2015 12:59pm |
No problem
There is a 'little' bit of info here: http://www.defender2.net/forum/topic25267.html |
8th Apr 2015 1:10pm |
