![]() | Home > Tdi > Newbie Question About Sluggish Performance |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
The 300TDi engine should not give you any problems on hills, so there must be something wrong, have you checked all the pipes attached to your turbo for leaks and firm attachment, sometimes a leaking turbo pipe can drastically cut down engine performance.
Other than fitting a full sized intercooler the only other option for more power is proper timing, setting tappets correctly or tweaking the fuel pump. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
chrispy Member Since: 13 Mar 2015 Location: Gwent Posts: 347 ![]() ![]() ![]() |
Thanks for that my friend. There was a whopping big intercooler already installed in it when we bought it a month ago. I'll check the pipes and see what's happening, many thanks.
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 ![]() ![]() |
I had a turbo pipe split once. On hills I just had to keep changing down the gears until I crawled over the top in second
I'll check it out tomorrow, thanks
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1117 ![]() ![]() ![]() |
did you sort it chrispy
No mate, tomorrow when it's daylight. Been choka block all day today sadly. It's a recon turbo on there (only bought about 6 months ago with all new pipes) so i'm thinking if it's not a broken pipe (which I doubt) maybe something wasn't put on right when it was put back on. I'll probably end up taking photos to show you guys as i'm new to this working on your own car gig and it's quite exciting the thought of being able to repair it myself
All pipes are fine and not cracked or split. In fact they're all new.
Afternoon Chrispy.....
Try this for a kick up the pants....... ![]() ![]() All you need to know....with pictures: ![]() http://www.landyzone.co.uk/lz/f8/sluggish-...46991.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Many thanks my friend.
