Home > Maintenance & Modifications > swapping out mud flap brackets and front bumper Advice |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 |
I fitted Entreq Stainless Steel mud flap brackets to front and rear, these are powder coated black so look stock. Down side is they are horrendously expensive but I was prepared to pay for something that is never going to corrode unlike the originals.
2nd Apr 2015 8:29am |
ive not had a problem front bumper corrosion but first four ones seen to be better made
flap mounts , for cheapness buy replacement ones and rub down and repaint better before fitting and put some anti rust wax on the bolt threads before fitting and on the mating surface between bracket and chassis |
2nd Apr 2015 8:39am |
90mojo Member Since: 19 Mar 2014 Location: UK Posts: 175 |
Very timely advice Munch90, fitting a set of new LR front mudflaps to my 90XS HT this weekend.
2nd Apr 2015 8:50am |
nice thick layer of black wax on mating surface (you will get messy ) bolt up so waxoyl oozes out of joint , wipe off excess from along joint , seals the joint stopping water getting in
plenty of waxoyl on threads ( very commom for seizing up ) , because you will need to take off again at some time , there mud flats so will get stone chips in paint etc |
2nd Apr 2015 9:03am |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 |
Thanks for the replies so far guys.
will check cost of originals verses nakatanenga ones. Has anyone found a top notch Bumper replacement? |
2nd Apr 2015 9:49am |
Sorry Steve E it wasn't Nakatanenga it was Entreq that I fitted, bought them from 4x4 Overlander.
2nd Apr 2015 10:49am |
Canberra Man Member Since: 31 Oct 2011 Location: Staffordshire Posts: 15 |
Steve E
Take a look at Devon 4x4, enter D44DEFNOWINCHSTD in to the search box. 5mm heavy duty bumper with some serious front recovery points. Received mine last week, not fitted yet but I'm very impressed with the build quality. Treat yourself to some stainless fixing bolts at the same time |
2nd Apr 2015 12:31pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Take a look at the Gwyn Lewis front mud flap kits on our website.
Galvanised brackets and they move the front flaps forwards to stop muck up the side of the doors. Also included are panels to 'finish' the inner wheel arch, protecting the outrigger |
2nd Apr 2015 12:51pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5111 |
Got fed up with bumper rusting so fitted a stainless steel one. Front and back Mud flap brackets replaced with Galvanised ones and sprayed black.
Click image to enlarge For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
2nd Apr 2015 1:38pm |
Thanks guys
Will post pics once I've swapped out. |
2nd Apr 2015 4:37pm |
Even with standard wheel and tire sizes I would make a case for the Entreq front mudflap extensions. Sit about 3 cm further out, so help (a bit) to keep the side of the truck cleaner when it rains. They are especially top SS quality, and I have proof that 1.5 years after I installed them, the powder coating remains as new.
Here is an installation link with before 'n after pictures... http://www.defender2.net/forum/topic22400....t+mudflaps For those with a 110, Entreq do not offer a replacement set for the rear mudflap holders, so I bought those from Offroad-Tec. Good quality by the looks of it too, but must admit I still have those in storage as my original rear mudflaps still are like new, and I just have the Entreq reinforcement brackets on those. Here is the Offroad Tec link to the product. http://offroad-tec.de/shop/main_bigware_34...ems_id=158 Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
3rd Apr 2015 4:10am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3645 |
ebay eBay Item No. 321708245826 DEFENDER 90 TDCI XS,
3rd Apr 2015 5:48am |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Hi Steve ,as above but a non winch on mine, quality very good.Been fitted to mine for about 2 years and still looks as good as new. |
3rd Apr 2015 6:21am |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 |
Another vote for the Gwyn Lewis mudflap kits, available from Matt now.
Definitely the best mod ive done, had the front kit on my last 3 defenders and will get the rear kit they now offer at some stage. 10/ 10 and look so neat aswell as protecting the sides and outrigger. |
