Home > In Car Electronics > What slim Subwoofer and where in a 90 HT |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
The genuine subwoofer cubby is actually shorter than a standard one.
This doesn't matter in a 90 but will foul the 2nd row seats when folded in a 110 |
3rd Apr 2015 8:34am |
Buy one of our shorter cubbys
I've also seen them mounted under the second row seats on the seat itself ... |
6th Apr 2015 7:25pm |
I have a focal i20 and I've fitted it under middle row seats .. Alternative place under front seat using entreq seat adaptor box
6th Apr 2015 7:26pm |
need4speed Member Since: 23 Nov 2012 Location: Kilmarnock Posts: 746 |
I want to fit the Alpine sub as well, though I will need to think of somewhere else to mount it as there defo won't be enough room after fitting your twin din cubby into my 110HT.... |
6th Apr 2015 7:31pm |
That's for sure
Don't forget that subs don't need to be 'symetrical' ie you can put it in a corner or off to one side |
6th Apr 2015 7:35pm |
Cool. Maybe onto the bulkhead behind passenger seat would do the trick.
6th Apr 2015 7:53pm |
That would be perfect !
It would be worth mounting it on a piece of thick MDF first (perhaps covered in carpet for aesthetics) to stop the bulkhead steel vibrating |
6th Apr 2015 7:55pm |
Yeah my whole bulkhead will be covered in vibration damping material as I will have an ARB compressor mounted on it as well.
6th Apr 2015 7:59pm |
6th Apr 2015 8:00pm |
nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 719 |
Martin, as i ordered a new leather cubby top from you last week , a whole new shorter cubby box may be a bit of a push. Under the seat sounds like an option worth considering. |
7th Apr 2015 10:20am |
