Home > eBay & Bargain Spots > Twisted alloy wheels x5 on ebay |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 |
Just spotted these might be of use as know lots on here like them
http://www.ebay.co.uk/itm/161650991829?_tr...EBIDX%3AIT |
26th Mar 2015 2:02pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4792 |
I spotted them as well but am only interested in the 18" variety. If you look at picture 11 there looks to be a small flat spot in the rim at about 10 o clock? It could just be me but it does look a bit out of shape to me 2002 90 Td5 Station Wagon
27th Mar 2015 7:38am |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Good spot grafty
Looks like you're right, on the 5th spoke at 10 o'clock it looks definitely looks like a damaged/flattened rim, I'll enquire. |
27th Mar 2015 10:28pm |
I'm glad im not the only one to see it. I'd be interested to hear the response 2002 90 Td5 Station Wagon
28th Mar 2015 1:31am |
There is also a wheel that has a chalked 'B' at the one o' clock position on the tyre, that rim has a nick in it at the five o' clock position. Despite claiming the wheels have been powdercoated and not fitted I think they have been touched up too but not sure as it may be bead lube splatter? If you go through life with your head in the sand....all people will see is an ar5e!!
28th Mar 2015 8:53am |
Seller has responded saying he's sure there's no damage but he's going to have a look and get back to me later.....
Here's the reply..... Hi Paul I had a look at that wheel this morning and your right it does appear to have a slight flat on the edge. I've just taken the wheels to be balanced and that one only needed a few weights so it must be running true. I don't know if it is from when the wheels were made as I purchased them second hand. Thanks Again .. well spotted grafty. It's a long way to go for me anyway to find problems and a have a wasted journey. |
28th Mar 2015 9:23am |
28th Mar 2015 11:20am |
