Home > Tdi > six speed tdi?
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
six speed tdi?
Came across this adaptor from M&D. What do you think?
http://www.ebay.co.uk/itm/170651925809
Post #410142 23rd Mar 2015 12:08pm
Personally I would think that there would be drivability issues due to the fact that the gearing is better sutied to the torque characteristics of the TDCi, and in low box first and reverse would be dangerous in novice hands due to the lack of idle jack.
However it would be interesting to hear experiences from someone who's actually fitted on and tried!
Best of all, you end up with a TDCi driven plate in the clutch, with a life expectancy of about 50k miles before the springs fall out! Big Cry
Post #410160 23rd Mar 2015 1:22pm
steventheplumber
Back to the drawing board
Post #410164 23rd Mar 2015 1:49pm
Name from the past - I remember M&D from the days I put a Perkins 4.182 diesel in my Lightweight. Thumbs Up
Post #410466 24th Mar 2015 10:16am
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
Wasn't there a pink and grey 90 on the Mobile Centre stand at the Land Rover shows last year?
I'm sure that was a six speed mated to a TDi engine and they said it was brilliant.
I think IRB may have been involved with it.
Try speaking to Ian at IRB.
Post #416359 15th Apr 2015 10:25am
shaggydog
I would be very interested in a 6 speed Tdi But by all accounts I have heard that it would be much the same until you hit 6th gear and then you would have to floor it up to 75 in order to maintain the torque required for the 6th gear.
For what its worth and the expense of a new 6 speed box and the faffing around involved I would rather spend the money on a Rocky Mountain Overdrive and get what is effectively a 6th gear anyway. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #416365 15th Apr 2015 10:38am
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
You'd need a 1.2 transfer box to at least otherwise 1st would literally be non-existent.
The only down side is you dont have any of electrickery (cant remember it's official, something like spike, or hike) when descending as the gearing is way to low and could cause you to slide rather than descend controllably.
Not to much of an issue if you descend in 2nd though, just for the real steep stuff!
Post #416390 15th Apr 2015 1:00pm
shaggydog
Exactly Thumbs Up
Stick with a Tdi Box and ether get a overdrive or look at swapping out your transfer box for a 1.2 one, there are lots of them around just be weary as not all of them have diff lock. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #416391 15th Apr 2015 1:09pm
g-mack
or ashcroft can put a longer ratio 5th in the r380 box! Thumbs Up My 109 thread
my youtube channel
Post #416397 15th Apr 2015 1:49pm
shaggydog
Very true G-mack had forgotten about that option. Thumbs Up
Is yours fitted with one?
(also did you sort your droning issue in the end?) Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #416398 15th Apr 2015 1:53pm
g-mack
no mine hasnt but i think if i ever had to change box i would go for that option its not that expensive iirc.
nope still droning lol. not done a single thing to the motor over the winter months but drive it! now the weather is improving i'm going to start again with the upgrades and repairs Very Happy My 109 thread
my youtube channel
Post #416400 15th Apr 2015 1:59pm
shaggydog
Sounds like a good option.
I have to pull my box out at some point as its using a litre of oil every 2 months how which is bordering on excessive Rolling Eyes Might consider a snubby R380 to replace it but not sure yet. Will see how the finances are looking when it comes to it. Besides oil is much cheaper than gearboxes Laughing
Glad to hear your still out and about had gone a bit quiet for a while. Looking forward to seeing your updates Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #416401 15th Apr 2015 2:07pm
taazzukcb
I've just had a new GBox and forgot about the V8 5th! But mine came from another source so dont know if it was an option.
Just had the TBox rebuild to in a bit of an emergency as when the box came off, the transfer didn't look great! Because of time constraints, the people who rebuild my transfer box didn't have time to strip a Disco TBox to get the 1.2 gear so not got that either Sad! Pain in the bum!
Keep thinking about overdrive, but £1600-1700 all in is verging on insane. It would take years of fuel saving (if I get any) to balance that out!
Post #416419 15th Apr 2015 3:05pm
