Home > Puma (Tdci) > EGR connector plug
CapeLandy
South Africa
EGR connector plug
I can't for the life of me figure out how to get the grey plug off the EGR valve.
Do i insert a screwdriver or how does it release?
Post #35681 6th Jul 2010 10:54am
MK
Dont have the rig to look at, but if it looks the same as the plug going into the fuel rail, then you have to press a plastic lock and then pull off. Puma 110" SW
Post #35682 6th Jul 2010 11:38am
CapeLandy
South Africa
found how. Insert screwdriver from upper end into slot and press lightly inwards and pull plug.
Post #35684 6th Jul 2010 12:23pm
might be a silly question, but why do you want to disconnect? by disconnecting, i'm guessing you are disabling the EGR ? is that all that needs to be done on a puma? I had a kit for my td5
Post #35710 6th Jul 2010 6:35pm
Grockle
you seem to be on a stripping down mission James 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #35740 7th Jul 2010 7:49am
