Home > Technical > Lockable dislocation cones
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Is there such a thing?
Lockable for on-road use, unlockable for off-road use... (of course)
Post #409217 20th Mar 2015 10:46am
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Why would you want lockable dislocation cones?
When on road you springs will never dislocate,only when off road.
Confused
Post #409218 20th Mar 2015 10:50am
zone30
Belgian MOT...
Post #409251 20th Mar 2015 1:02pm
shaggydog
But surely the alternative is standard spring setup in which the top is free to do as it wishes anyway?
Can't see the issue there Confused Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #409253 20th Mar 2015 1:03pm
davew
Re: Lockable dislocation cones
Point out that they are not "dislocation" cones, they are relocation cones. They don't allow the spring to dislocate because the spring can do that when it comes out of the factory. All the cones do is make sure that when the spring comes back up it relocates into the correct place. If your MOT tester fails the vehicle for having them then he/she has failed to grasp the design of the vehicle.
There is nothing on a standard Defender to hold the top of the spring in place other than the proportion of the weight of the vehicle that is on top of it. Locking the top of the spring in place will bend the bottom retaining bar and eventually allow the bottom of the spring to come away from the axle and when that happens the relocation may well miss the axle completely.
Bottom mounted relocation cones (which are better in my view) might cause your MOT man to question it as that is a change to the way the spring is mounted and works but a top mounted relocation cone has absolutely no effect on the suspension configuration in normal operation. http://www.yorkshireoffroadclub.net/
Post #409265 20th Mar 2015 1:52pm
ex_mod_90
I have used these with great success:
http://www.gwynlewis4x4.co.uk/product/chal...ed-110130/
Problem I found with the reverse type, as described above was the spring missing the cone when relocating in thick mud. Once I changed to the Gwyn type in the link above, no further problems.
Rich
Post #409410 20th Mar 2015 10:06pm
landy andy
On a standard setup relocation is not required as the spring can not dislocate, due to the length of the damper, so no clamp, or relocator needed. I thought dislocating suspension was not allowed in the uk either, but I run Gwyn Lewis challenge kit so the spring is caught by the relocator, so does not dislocate.
Post #409534 21st Mar 2015 1:01pm
Don't you just want a set that come with the check strap that will limit drop?
Who had the set that had a snap hook type arrangement for de-coupling when you did go off road?
Post #409837 22nd Mar 2015 10:46am
munch90
the check strap set up was more for if you needed to jack the car up to change a wheel , then you put the strap on so you could get the wheel off the ground with normal jack
something people don't think about when they fit longer shockers , but they find out when stuck with a puncture at side of road and you cant get enough height to change the wheel Laughing
ok if you got a under axle jack if not your Censored !
and to get the height with a hi-lift jack its too unstable for my liking
Post #409846 22nd Mar 2015 11:08am
zone30
Rich
I like those!
Yet another question: what else is required to have full use of such a system? Longer shocks, I understand, but do you need to extends stuff (e.g. brake lines) like with a lift?
I am not a fan of lifting but is it so that with relocating cones you will keep the car more level on a side slope? That's my main reason why I am looking at this feature...
Had some scary moment a few months back, especially with the top weight:
Post #409853 22nd Mar 2015 11:33am
munch90
could be a different question there
if your on a steep sideways slope then really you want as much weight as possible pulling the defender back over so would it be better not to have wheel resting on the ground and instead the weight of the wheel pulling body back , maynot be that much weight but it all must help
I think the axles dropping is more for traction then stability as for traction if there is no weight pushing that wheel down its not going the help much anyway
really you need active suspension to help there as in air suspension but that a whole new ball game then !
Post #409869 22nd Mar 2015 12:15pm
lateral thinking - was trying to solve Op's issue with Belgian MOT...
Post #410007 22nd Mar 2015 8:18pm
munch90
I know what you mean , to stop axle dropping on mot maybe , but do they jack up on the body for mot over there , if they jack on the axle like here then they would not know if the axle drops or not
dont know anything about Belgium mot procedure
but i think he is thinking about fitting them for the wrong reason as he is on about on a side ways slope and i think that it would make things worse for sideways stability
Post #410014 22nd Mar 2015 8:30pm
zone30
Bad idea, got it Rolling Eyes
Thx!
Post #410404 23rd Mar 2015 10:37pm
Mo Murphy
You could always take all that unnecessary weight off the top.
Just trying to help Very Happy
50 Shades of Pennine Grey
Post #413524 3rd Apr 2015 3:15pm
