Home > Maintenance & Modifications > Swapping door rubbers from body to door |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
mmmmmmmmmm........ this sounds like an interesting idea, i think it may be that the only reason its not been done before is "thats the way its always been done" thinking.
5th Jul 2010 11:48pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2429 |
Dust: mission impossible
I would not swap the rubber to the door frame. You can glue the seal to the body with silicone. You could as well apply the sealant to the frame leaving a straight line of about 1-3 mm. Worked for my rear door. Puma 110" SW ............................................................. Earth first. Other planets later |
6th Jul 2010 1:16am |
