Home > Technical > ECU for remap? |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Speak to Pete at BAS
As I found out when he mapped my 2.2, if you are sending another ECU to be mapped it has to be a new ECU not a take out - Pete will explain why. He also sells new ECU's. I run two ECU's, no issues with odometer or alarms etc. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
10th Mar 2015 11:46am |
jayaway44 Member Since: 04 Nov 2011 Location: Edinburgh Posts: 111 |
Hi Bob what is your overall impression of the remap. 2.2 2012 110 utility Orkney Grey
Also Range Rover Evoque - Surprising but I like it. Previous Freelander 2 SD4 HSE - Black 90 TD5 Discovery 3 Early Discovery. |
10th Mar 2015 12:47pm |
Love it
The engine is a lot smoother and quieter when cruising, rpm reduction is probably why. Acceleration, especially 3rd, 4th and 5th, is really good - taken a few Audi/BM drivers by surprise Couple of small niggles that I am sure I will get sorted sometime. Still get a bit of Kangaroo'ing in 1st/2nd but I am sure most of this is due to the sensitivity of the throttle pedal. Rev hang from 4th to 5th is more pronounced especially if I am driving it hard. Same or slightly worse fuel consumption but that is down to the fact that I do like to make use of the power now available Overall it has made the vehicle a lot more drivable and also made it more enjoyable to drive. The only downside, if you can call it that, is the fact I have got to put the standard ECU back in this week so I can get the vehicle serviced - no I don't trust the dealer not to wipe it clean !!! Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
10th Mar 2015 1:16pm |
