Home > Technical > Siren BBUS AMR4972 |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 323 |
Just seen this thread - don't know how I missed it before.
BBUS AMR4971 was only ever used in the P38RR, and will use a different signalling method between the control unit and the BBUS AMR4974 was the one that was fitted to the Defender and also to the Disco1. This been superseded several times and the one currently available is LR044570, the part number history is: AMR4974 fitted to 1996-1998 YWK100130 fitted 1999-2007 YWK100131 fitted 2007 LR012194 fitted 2008 LR014059 fitted 2009-2012 LR044570 - latest Dates are approximate. So any BBUS with an AMR part number is going to be at least 17 years old - don't think I'd trust the battery on one that old. |
22nd Mar 2015 7:09pm |
I brought a new one as its hard to tell what real condition the battery will be in on a s/h one
22nd Mar 2015 7:12pm |
Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388 |
So YWK100130 is the one for my 2005? Will the latest version work on an TD5 Thank you for your advice. Keith 2005 TD5 90 CSW XS |
23rd Mar 2015 10:31am |
YWK100130 is the one that would have been fitted (if specified) in production, all the part numbers in the list now supersede to LR044570 i.e. that should work in place of any in the list.
If it was fitted in production, my vehicle should have had LR014059 - I fitted LR044570 and it works fine. |
23rd Mar 2015 5:31pm |
Right ok I need to buy one of those then £100.00 plus vat is the cheapest I've seen, do any of the site sponsors do them any cheaper does anyone know?
Thanks Keith 2005 TD5 90 CSW XS |
24th Mar 2015 9:01pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
Check with Dan at Duckworth parts on here
24th Mar 2015 10:17pm |
