![]() | Home > Wheels & Tyres > tyre wear |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Tracking issue combined with uneven inflation, perhaps?
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
I've noticed my front o/s tyre has worn much more than the other side.... Roundabouts maybe??
pressures ok and tracking seb or both would have worn on the inner edges ie towing out, could be Tim I'll ask them to check the camber whilst it's in for the 24k service tomoz
thanks anyway chaps ![]() 1968 1/32 scale Britains 109 Pick up. |
Mad Cow Member Since: 27 Oct 2009 Location: Hertfordshire Posts: 292 ![]() ![]() ![]() |
In my experience roundabouts tend to wear the front near side tyre more (in Countries where we drive on the correct side of the road that is). A partcular problem round my neck of the woods in Stevenage, as with any new town, it's roundabout city ![]() 2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport Project90 |
camber is non adjust,so I'll get them to check the tracking,roundabouts could be the cause I'll swop them over an keep an eye on it 2.4 90 XS
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2463 ![]() ![]() ![]() |
You should not swap tyres between sides. Front to back is ok. Puma 110" SW
gtveloce65 Member Since: 10 Nov 2008 Location: West Sussex Posts: 107 ![]() ![]() ![]() |
My RR classic used to wear the outside of the NSF and inside of the OSF tyres - never had a problem with the old Michelin M+S tyres (which were rock solid and used to last for 40,000 miles + on the back) but the horrible Pirelli Scorpions were dreadful.
I was talking to someone who ran Defender 90s towing large trailers, and although the tyres lasted them for ages, they had the same issue - we agreed it might be a combination of UK road camber and roundabouts... 1953 80 1965 Alfa Romeo GT Veloce Sprint 1980 Fiat 124 Spider 2008 110xs |
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 671 ![]() ![]() ![]() |
I've still got the Grabbers on....Can't wear the bloody things out, 30,000 miles aint even touched them
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
All tyres you should move the fronts forward and the rears across and back.
BFG recommend that ![]() Evens up wear increases longevity etc Mike |
I believe the manual states not to do it. Puma 110" SW
I would strongly suggest it doesnt Mike |
