Home > Puma (Tdci) > Cold Climate Pack |
BarneyRubble Member Since: 08 Mar 2010 Location: Naphill Posts: 103 |
Anybody know if it is possible to retro-fit heated seats & front screen to a County?
I've seen the discussions about the front screen, but what about the heated seats? Barney |
29th Jun 2010 7:44am |
yes you can.... I installed a carbon heater elements bought on ebay.......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
29th Jun 2010 8:12am |
What, something similar to this?
Is the wiring not already installed then? |
29th Jun 2010 9:10am |
yes.....
no, you must install a new wiring loom. if you (like me) want to replicate the original Land Rover wiring scheme, you need to take a signal from the tacho unit (ENGINE RUN SIGNAL) not so difficult ..... pm me if you want other infos, so I scan my "study" made for my front screen "upgrade" Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
29th Jun 2010 9:21am |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 |
Not really that difficult.
Is it a TD5 or Puma? You could either do some wiring yourself, or (as I did) replace your loom with a cold climate pack loom which will already have connectors for screen, seats etc. Much neater job and it has correct switches, relays etc. You can then use the factory switches and only need to buy the seat heater pads. My blog - www.anacreinhampshire.blogspot.co.uk 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
29th Jun 2010 10:30am |
It will be a Puma (when I get it).
I'm looking for a cheap Hard-Top or Pick-Up, but can't find any with the Cold Climate Pack fitted. Have you any details of the replacement wiring loom or other parts? |
29th Jun 2010 11:14am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
the only problem I had, is that there isn't any wiring for the screen, but quite a few people have managed it 2.4 90 XS
30th Jun 2010 8:19am |
Anyone got the fitting instructions for the Exmoor Trim heated seats?
They couldn't be less helpful when I asked them. |
30th Jun 2010 5:13pm |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 |
Theres a PDF file on Exmoor Trims website. 130 crew cab 98 V8 Disco |
1st Jul 2010 9:32am |
Can't find one.
Emailed them & they said they don't have one, it comes as part of the kit. |
1st Jul 2010 10:06am |
I have a copy here but don't know how to post it. PM me with your Email and i'll send it to you. 130 crew cab
98 V8 Disco |
1st Jul 2010 10:44am |
130 crew cab
98 V8 Disco |
1st Jul 2010 11:10am |
Cheers parktag,
Instructions are here if anyone is interested http://www.defender2.co.uk/gallery/albums/...ctions.pdf |
1st Jul 2010 11:32am |
