![]() | Home > Technical > Drag Link - Shorten How ? |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 842 ![]() ![]() ![]() |
Sounds like you might be getting mixed up with the steering damper? The drag link is a plain metal rod about 22mm thick. The only way to know which way to turn the rod is trial and error or see if you can see any exposed threads at the end and work it out from there.
V12vanquish Member Since: 28 Sep 2014 Location: Northern Ireland Posts: 52 ![]() ![]() ![]() |
I recently adjusted mine to correct the steering wheel running off centre.
Just slacken the clamp at each end and turn the tube, from memory I think downwards shortens it. About 1/2 a turn makes a fair difference, if you go the wrong way, just do it again and turn the other direction. There are a few posts on here about this. |
Sounds more like your steering wheel just needs to be moved one spline over? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter ![]() |
You need to centre and lock the steering box with a pin to make sure the wheel in on the correct splines before moving it, it may just be the drag ling.
Just done mine today. Swan neck damper bracket is a L/H thread and the corresponding TRE at the passenger wheel is R/H thread.
SingletrackFred Member Since: 23 Mar 2015 Location: Reading Posts: 66 ![]() ![]() ![]() |
I have the same issue on mine.
I loosened off the clamps, but can't move the drag link. Should it be easy to rotate? Any advise would be useful |
