![]() | Home > Tdi > Britpart Spring Question |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Personally I would avoid Britpart springs ..... My experience is the spring rates are inconsistent and usually Rock hard.
There is an array of standard springs available - and with some research you can get the ride and ride height you want with them. They are good quality and not as expensive as you might expect. |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Are right ok it was just a thought
![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
redzob Member Since: 16 Jul 2014 Location: St. Peter Port Posts: 137 ![]() ![]() ![]() |
I was playing with this and ended up with progressive rear springs from the guys at extreme4x4. Very helpful and would recommend.
![]() Vespa GTS 300 Way too many racing bikes. |
Whats the difference with normal and progressive springs
As I understand it, they have two rates of compression. The standard 90 ones are rated at 225lbs, but my new ones are 150/220lbs, meaning a generally softer ride (150) until the rear is either loaded up or hits a really big bump/pot-hole. You can get various different rates depending on your requirements (there's always a trade off between load carrying ability and ride quality).
I tried two different pairs before finding what I was after (my 90 very rarely carries load, I wanted to improve road manners and had already upgraded to bilsteins all round) I'm sure there are far more competent explanations elsewhere on the forum, but this seems to be working for me... Defender Puma 2.2 XS 90 Vespa GTS 300 Way too many racing bikes. |
Are right i see
