![]() | Home > Expedition & Overland > Hicap dimensions |
Juddy Member Since: 09 May 2013 Location: Queensland Posts: 63 ![]() ![]() ![]() |
110 or 130? 2010 Defender 130 HCPU
1991 110 RFSV PERENTIE www.landybitz.com.au |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 ![]() ![]() |
Don't mind, it's the height from the bed from the floor to the top go the tub I really need.
Maris Widgeon Member Since: 11 Dec 2013 Location: Cotswolds Posts: 216 ![]() ![]() ![]() |
Back in the truck today after a weekend off so have been able to get you some measurements.
This is taken from a 2014 110 hi cap. Width = 1710mm Length=2070mm Height=495mm(internal floor to tub edge) Hope this is what you are after. |
Spot on, don't suppose you could measure the distance from the top of the tub to the gutter of the truck cab? Approx will be fine. Appreciate it lots!
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
Think it's about 440mm (from memory) 130's have feeling's as well you know
From the top of the tub to the roof gutter is
540 mm Hope this everything as its raining outside ![]() ![]() Nick |
