![]() | Home > Puma (Tdci) > Is it me or is there something missing |
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 ![]() ![]() ![]() |
![]() WAXOYL ! Get some in there ![]() |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
2nd battery
mse Member Since: 06 Apr 2008 Location: UK Posts: 5087 ![]() ![]() ![]() |
Whilst both very correct (although i would choose standard hammerite in there (external and clamps done waxoyl) and the second battery is a little down the line after the last finance hammering!
No i was thinking more concerning factory fitted bit - the clamp that holds the battery down!! thats 3 factory missing bits! - unless anyone tells me there is a new way of clamping it down. Mike |
Is it loose then?
IIRC does it not clamp on the lip on the bottom of the battery and not over the top like the old ones? BTW I personally gave up using using Smoothrite yonks ago, it's too brittle and liable to chip. |
Hammerite is great stuff - ive used it for loads works really well - but application is key (ish). Mike |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6661 ![]() ![]() ![]() |
It's clamped down at the bottom
The clamps can be seen in the photo and are held with the 2No extra long screws
