Home > Maintenance & Modifications > Headlight relay loom - connect to alternator
Flyingfocrs
Scotland 2011 Defender 110 Puma 2.4 USW Santorini Black
So I just installed my Landreiziger headlight relay loom today and have seen on here and elsewhere that it is impossible to connect direct to the alternator on a Puma TDCi so has to be extended and fitted to the battery.
Well I just connected mine to the alternator and didn't find it overly difficult to do so.
I removed the air intake hose and then disconnected the hose from the bottom of the turbo as well.
This when tucked out of the way gave plenty of access to get a hand in and remove the nut, fit the cable and refit the nut.
Post #399692 17th Feb 2015 4:53pm
jimbob7
Quality bit of kit that Landreiziger loom!! Pov.spec,ftw. 2006, 110,TD5.
Post #399730 17th Feb 2015 6:38pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
In the first pic is it me or does the hose below the cable look rubbed or misshaped ?
Not sure what it does ? May be its under pressure to make clearance while doing this ! It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #399745 17th Feb 2015 7:04pm
munch90
Its the hard plastic pipe from wing intake to air box and they are a bit mishaped anyway im sure
Post #399747 17th Feb 2015 7:09pm
sparkylee
Cheers ^ It's good to be back from the dark side
FFRR 4.2 vogue
Post #399759 17th Feb 2015 7:20pm
ericvv
My Landreiziger loom was installed by my dealer, and they also connected the permanent live to the starter motor or the alternator of my Puma without a problem (thanks to their lift I guess). Additionally, in order to have a perfect negative (mass) lead, they extended this black cable a bit and then connected this onto the airco compressor which is not only easy to reach from the top, but which has a nut screwed in which has no real use, so seemed to be waiting for this mass cable. According to my dealer this is the best mass you can find for this Landreiziger loom Thumbs Up
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #399804 17th Feb 2015 8:12pm
munch90
That bolt that has "no real use " is a mounting bolt for the compressor , it goes right though the pump to the mounting plate at the back
Still ok , but thought you might want to know Rolling with laughter
Post #399807 17th Feb 2015 8:19pm
ericvv
Post #399811 17th Feb 2015 8:25pm
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Re: Headlight relay loom - connect to alternator
Thank you - exactly the info I was looking for...
Post #495977 24th Jan 2016 9:58pm
Alexke
Belgium
Eric
I would make sure that bare copper has some Solder on it (it will corrode and add resistance) Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #496453 26th Jan 2016 12:43am
pme
United Kingdom 2007 Defender 90 Puma 2.4 SW Tonga Green
Has anyone fitted the boomslang version, any problems to look out for?
Post #504056 12th Feb 2016 7:52pm
Cupboard
Yes I have.
No major issues I don't think... I can't really remember much which means it can't have been too much of a job! Did find that the fuse's plastic had melted (but was still working) after a while though.
Post #504070 12th Feb 2016 8:26pm
Swac3
On the subject of soldering to reduce corrosion in a crimp terminal, I wouldn't bother to be honest.
Vibration and flexing can cause even good solder joints to crack if not properly supported and then you have a small fissure for water ingress with much less chance of drying out, also soldering multi strand wire produces what is effectively a solid wire with the stress point now at the crimp, flex or the lack of it in solid cores is why multi strand cable is generally specified in machinery with vibration potential.
Engine bay ones see quite a bit of heat so generally shouldn't present any moisture problems.
the worst will be areas where we tend to get lots of mud/crud build up like underside of the rear tub but even then unless you hermetically seal the termination, solder in the crimp wont protect the copper conductors behind the crimp where you've stripped off the insulation and your cable will corrode just not at the crimp but rather to the rear of it.
A properly formed crimp termination shouldn't really allow water to wick along the conductors into the crimp body, but given the quality of most auto crimps and tools then maybe that's a possibility.
Mil spec crimp terminals aren't soldered nor are aircraft wiring crimp terminations. 3 Landrovers
Post #504081 12th Feb 2016 8:47pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Yes, a properly crimped terminal forms a gas tight joint. But you are also right that most auto crimps and crimping tools are pretty poor quality.
Post #504113 12th Feb 2016 9:32pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
You're entirely correct, but then again the solution shown by Eric is, sorry to say, a poor one from reliability point of view.
This type of crimp terminal should be protected from the elements, like virtually all crimp terminals should be.
Now it is exposed making it just a matter of time before it will be corroded.
Luckily, Eric only drives his SVX on sunny days, so he should be fine for many years to come Laughing but I would not take this as a good example Embarassed
Actually, with some skill and practice one could solder-seal the tip of this crimped connector without the rest of the wire wicking up the solder.
But this is not really practical either and difficult to control during soldering.
The least thing to do is install a small protective cap over this bolt.
But I'm wondering, how hot does an aircon compressor get when it is working hard ? Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #504117 12th Feb 2016 9:38pm
