Home > Maintenance & Modifications > Bilstein shocks??? |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
I've got the Bilstein shocks on mine and they totally change the ride NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
20th Jun 2010 9:11pm |
Fekete, could you explain me better???? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
21st Jun 2010 9:37am |
Hi dg, when i say they totally change the ride meaning smoother...and the drive is a lot more tolerable.....for instance when i go across really rough ground the 90 used to rattle to bits now there is hardly any rattle as the shocks are doing there job NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
21st Jun 2010 9:54am |
Interesting... have you the reference for the correct Biltein for the 90' Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
21st Jun 2010 10:07am |
I have on the front 625670020 bilstein shock H/D £55.00 each
On the rear 625530030 bilstein shock H/D £75.00 each hope this helps NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
21st Jun 2010 10:12am |
DG, For instance when crossing something like this cobblestone roads you can really feel the difference
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
21st Jun 2010 10:27am |
