Home > My Defender > My V8 90 Auto rebuild. |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Overland Journal?
25th Oct 2016 8:14pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 |
I already have a load of them don't want use them though.
25th Oct 2016 8:17pm |
Give me one
(On kidding BTW I know they are a pain to get over here, one day I'll stump up the postage) |
25th Oct 2016 8:20pm |
I have one of these I could spare, maybe.
25th Oct 2016 9:23pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3786 |
What a great thorough job you are doing Greeni.
I note your comments about the temporary nature of the air filter, so I ain't being no smartie, so I suppose it would be good if you could organize the engine to be sucking cold air from some sort of cold air intake, rather than hot air from under the bonnet. Can't wait, as others have said, to hear the rumble! Pickles. |
25th Oct 2016 9:29pm |
Well spotted pickles
It will eventually be isolated under there with either a cold air intake pipe taken from the unused wing top vent, or some 'speed holes' in the bonnet @tiger what did you get? I have a cap I've never worn also? You're welcome to that....if your wear caps! |
25th Oct 2016 9:41pm |
Don't wear caps very kind but would be a bit disingenuous
Just a couple of OJ & EP oval GB type stickers for back of 110 |
25th Oct 2016 9:57pm |
Stickers rule.
25th Oct 2016 10:04pm |
Greeni,..there is a "way" to take cold air from the rear of the engine bay, which was used by some GM U.S. Muscle cars, also used on some Aussie V8s, but you'd see it on late sixties Camaros etc, which had the cold air induction option.
At the bottom of the windscreen, a sort of vacuum forms, when the car is being driven, so the us muscle cars have a bonnet scoop, under which is a hole in the bonnet, but open at the REAR, which enables that air, comprising the vacuum, to be very easily & quickly sucked into the intake!! Pickles. |
25th Oct 2016 10:49pm |
Thanks Pickles, great bit of info. The plan was to reverse dimple-die it, so water can't run in and put a scoop over it, the trouble is, scoops look very 'rice' and can ruin the traditional look. A friend has a Subaru rally car and he has the scoop reversed.
There's a lot of ducts in the Demon Tweeks catalogue that I'll be looking at, for ideas. As long as it's done tastefully, they can look great. I've been saving this photo as inspiration for my next build (starting when Mrs Greeni thinks I'm ready!) check the bonnet. |
26th Oct 2016 6:12am |
Edit
27th Oct 2016 12:54pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Looks great How many Defenders do you have down your street!! Are they all yours? James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
27th Oct 2016 3:43pm |
Thanks. All but one !
27th Oct 2016 6:13pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10818 |
Is she off to get her running GREENI I recognise the the other truck cab there in the back ground 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
27th Oct 2016 7:34pm |
