Home > In Car Electronics > Dab Shark Fin Aerial |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
I have fitted one of these http://www.dabonwheels.co.uk/SharkFin_DAB_FM_Car_Aerial.html
I fitted it towards the front of the roof in a similar place to this but a bit further back. The reason for fitting it towards the front of the roof is the fact that the vehicle has a roof rack fitted so this was the only place it would physically fit. Thanks for the pic Buccaneer I drilled through the roof and also drilled a hole in the bottom of the rib big enough to allow a socket to pass through the hole to tighten the aerial fixing nut. The sides of the rib are still in place so as far as I am concerned there is little impact on the strength of the rib. The reception is very good in fact I get better DAB reception in the 130 than my Disco 4 130's have feeling's as well you know |
5th Feb 2015 9:03pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 |
Dab's the future, purely for Radio 6!
I'm gonna get one soon. |
5th Feb 2015 9:13pm |
Yes its under the rack and its got great signal, not been to Dorset in the 130 yet so cant comment on reception there. I live on the Welsh border and there are 'black' spots with reception, well there is in the Disco 4. So far I have not encountered any signal loss. 130's have feeling's as well you know
6th Feb 2015 8:03am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17470 |
There are areas in Dorset where a wireless set with valves is still considered a bit too new-fangled, and where the latest 4WD tractor is an ox!
6th Feb 2015 9:20am |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
Love my DAB I have an adaptor that allows the original antenna to be used for dab and fm. But my head unit has stopped receiving dab ! Its definitely a software fault I've tried a spare antenna the window one and still no signal 😞
6th Feb 2015 9:21am |
The really annoying thing with the Pioneer unit is that with this fault it still receives DAB fine but when set to DAB the display says something helpful like "ANTENNA FAULT" and the controls are locked, so you don't know what it's tuned to and you can't retune it anyway. But is still receives a signal so clearly there's actually no antenna fault. I think it is concerned with the circuitry used to power a powered antenna, but clearly it is moronic design. |
6th Feb 2015 9:33am |
I have powered my antenna from the vehicle not the radio 130's have feeling's as well you know
6th Feb 2015 10:01am |
Mine is passive, not powered, which makes me even happier about the internal fuse that's blown!
6th Feb 2015 10:18am |
shaun.mobile Member Since: 12 Dec 2011 Location: England Posts: 156 |
Andrew S, really like the look of that. I have a wing mounted dab aerial from dab on wheels and the reception is rubbish. it isn't just the signal either because I have had courtesy cars with dab and they have been flawless.
how easy is this to fit? does the headlining come out easily and more importantly, doe it go back without it looking like it has been tampered with? I have a jvc single din head unit with a jvc dab box. I was originally put off the shark fin because it didn't get a good review. |
6th Feb 2015 9:27pm |
Yes lining out, its easy enough to remove the lining dependent on how 'stuck' the fasteners are.. A lot easier if you have a trim removal tool. Get a few spare lining fasteners before you start the job.
Even with a trim removal tool the fasteners are sometimes difficult to remove without damaging the head lining, I use a pair of these to get behind the head of the fastener to pull it out. Or just snip the head off the fasteners that want to stay put. Once the lining is out you can easily remove the remainder of the 'stuck' fasteners. 130's have feeling's as well you know |
7th Feb 2015 9:00am |
Went into Deepest mid Wales yesterday no DAB signal 130's have feeling's as well you know
8th Feb 2015 9:09am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Plenty of Sheep thou
8th Feb 2015 9:13am |
I live in Dorset what's DAB all about then?....... If you go through life with your head in the sand....all people will see is an ar5e!!
8th Feb 2015 9:16am |
Click image to enlarge 130's have feeling's as well you know |
8th Feb 2015 9:46am |
